Dat vraag ik mij af, heb zo'n plaat akotherm hier staan. Maar dat is bijzonder stugge troep.
Dat krijg je m.i. niet zo makkelijk verwerkt en getacked zoals dat in de calpamos gedaan is.
edit: nvm, je vraag ging over 't zachte Akotherm-achtige spul en niet de stugge dempingplaat
The inside of the cabinet is lined with 4mm thick bitumous vibration damping panels. Due to the high weight of these panels (andtherefore high shipping-costs), they are not included as part of the standard kit but can be supplied if they are not available whereyou live. I used Standartplast STP Aero Bomb but other products such as CTK Vibrodamping, Silent Coat Vibrodamping or DynamatXtreme are equally effective. Apply the damping panels to all internal surfaces except the baffle. It doesn't matter if a fewcentimeters along the edges of each surface are not covered. The damping panels are self adheasive but I would advise to takeextra measures to make sure they stay stuck in place for years to come. First of all, the inside surfaces of the cabinets must bedust and grease free. Then the panels can either be glued using vinyl glue as well as their own adheasive layer. Or you can stickthe panels as they are and then staple them to the cabinets for extra strenght. I chose to do the latter with the help of an electric staple gun.
The soft damping material used in the Calpamos consists of 50mm thick, black polyester fibre acoustic damping sheets. Each sheetis 1000 x 1200mm in size and one whole sheet is needed per loudspeaker cabinet. The damping material covers all internal area'sexcept for the lower part of the side walls near the woofer and also the bottom surface is left free from this soft damping material.
Ja die pdf kan ik ondertussen al dromen
Wat ik bedoel met stugge plaat is dit:
Akotherm Basic Akoestische Plaat | Dikte 50 mm | Wit | Densiteit 40 kg/m3 - artikel: K0423
"The soft damping material used in the Calpamos consists of 50mm thick, black polyester fibre acoustic damping sheet"
Maar jullie denken dus dat dit akotherm is?
Het blijkt in de calpamos toch akotherm D40 te zijn. Gelukje is dat ik daar nog wat van heb staan.
Het verwerken zal wel even wat gemartel worden. Maar ja zonder wrijving geen glans zeggen ze toch....
Ik heb het voor de zekerheid even opgezocht: in de Calpamos zit Akotherm D20 (ik dacht eerst de D40, blijkt toch D20), dikte 50mm, typenummer K0415. Dit is een zacht materiaal, wel stugger dan Sonofil, maar wat betreft vormbaarheid vergeljkbaar met noppenschuim.
Haalde het door elkaar met het (zware) 4mm dikke Standartplast STP Aero Bomb dat je in de tekst op je website noemt.
Misschien dat de mensen dit ook bedoelen, als in moeilijk te knippen, dat Akotherm lijkt me gewoon te snijden/knippen. Bedankt voor de reactie in elk geval.
Ziet er goed uit, ook alles netjes dicht gekit zo te zien
Goed voor de gemoedsrust. Maar als je de kast netjes in elkaar zet zal het praktisch weinig uitmaken, Als je een kast 100% luchtdicht maakt (wat niet zal meevallen) heb je een prima barometer gebouwd.
Mijn laagkasten zijn 100% luchtdicht, maar ik heb bij veranderende luchtdruk nog niet gezien dat de woofers naar binnen worden gezogen of naar buiten komen puilen.
Dat komt omdat die verandering zo langzaam gaat dat het wel door laat.
De tijd variabele heeft hier volgens mij niet zoveel mee te maken.
Maar het echt 100% luchtdicht kregen van een kast is zo goed als onmogelijk.
Zo zijn bepaalde conussen of rolranden toch nog enigszins poreus en heb je toch altijd iets van lek bij schroefgaten of achter de speakerrand. Dat hoeft maar een heel klein gaatje te zijn, drukverschillen zijn namelijk niet ZO groot.
