Zelfbouw grote speaker 2 of 3 weg
MechanicalAnimal
Re: Zelfbouw grote speaker 2 of 3 weg
koenjer schreef:
Shadow schreef:
Er wordt akotherm d40 gebruikt volgens mij;
https://www.akoestiekwinkel.nl/akotherm ... ptieplaten
Dat vraag ik mij af, heb zo'n plaat akotherm hier staan. Maar dat is bijzonder stugge troep.
Dat krijg je m.i. niet zo makkelijk verwerkt en getacked zoals dat in de calpamos gedaan is.
edit: nvm, je vraag ging over 't zachte Akotherm-achtige spul en niet de stugge dempingplaat
Had je die PDF al?
http://www.humblehomemadehifi.com/downl ... lpamos.pdf
The inside of the cabinet is lined with 4mm thick bitumous vibration damping panels. Due to the high weight of these panels (andtherefore high shipping-costs), they are not included as part of the standard kit but can be supplied if they are not available whereyou live. I used Standartplast STP Aero Bomb but other products such as CTK Vibrodamping, Silent Coat Vibrodamping or DynamatXtreme are equally effective. Apply the damping panels to all internal surfaces except the baffle. It doesn't matter if a fewcentimeters along the edges of each surface are not covered. The damping panels are self adheasive but I would advise to takeextra measures to make sure they stay stuck in place for years to come. First of all, the inside surfaces of the cabinets must bedust and grease free. Then the panels can either be glued using vinyl glue as well as their own adheasive layer. Or you can stickthe panels as they are and then staple them to the cabinets for extra strenght. I chose to do the latter with the help of an electric staple gun.
The soft damping material used in the Calpamos consists of 50mm thick, black polyester fibre acoustic damping sheets. Each sheetis 1000 x 1200mm in size and one whole sheet is needed per loudspeaker cabinet. The damping material covers all internal area'sexcept for the lower part of the side walls near the woofer and also the bottom surface is left free from this soft damping material.
koenjer
Bericht door koenjer »
Had je die PDF al?
Ja die pdf kan ik ondertussen al dromen :)
Wat ik bedoel met stugge plaat is dit:
Akotherm Basic Akoestische Plaat | Dikte 50 mm | Wit | Densiteit 40 kg/m3 - artikel: K0423
"The soft damping material used in the Calpamos consists of 50mm thick, black polyester fibre acoustic damping sheet"
Maar jullie denken dus dat dit akotherm is?
Nee, Akotherm is het stugge materiaal. ‘The soft damping material’ is het zachte noppenschuim, 50mm dik. Tenminste, zoals ik het lees.
VintageHarry
Bericht door VintageHarry »
Polyester fibre, dat lijkt me dan een BAF deken van 5 cm dik.
koenjer
Het blijkt in de calpamos toch akotherm D40 te zijn. Gelukje is dat ik daar nog wat van heb staan.
Het verwerken zal wel even wat gemartel worden. Maar ja zonder wrijving geen glans zeggen ze toch....
Met een beetje goede schaaar is t prima op maat te krijgen is mijn ervaring
+1 HJ, dat moet toch lukken...
Geenius
Bericht door Geenius »
Ik heb het voor de zekerheid even opgezocht: in de Calpamos zit Akotherm D20 (ik dacht eerst de D40, blijkt toch D20), dikte 50mm, typenummer K0415. Dit is een zacht materiaal, wel stugger dan Sonofil, maar wat betreft vormbaarheid vergeljkbaar met noppenschuim.
https://www.akoestiekwinkel.nl/akotherm ... che-platen
Ik begreep dat er vanuit Merford een speciale zaag te krijgen is voor het op maat maken van Akotherm...
Zaag? :shock:
Ik heb akotherm in de Mission Impossible zitten. Gewoon een schaar. Gaat prima.
OWC
Bericht door OWC »
Broodmes en een lat, gaat het ook prima mee.
Haalde het door elkaar met het (zware) 4mm dikke Standartplast STP Aero Bomb dat je in de tekst op je website noemt.
Misschien dat de mensen dit ook bedoelen, als in moeilijk te knippen, dat Akotherm lijkt me gewoon te snijden/knippen. Bedankt voor de reactie in elk geval.
koenjer
zijn weer stapje verder.
2e luidspreker zit in elkaar, boel voor de zekerheid maar extra af gekit.
Bitumen platen erin gemaakt en de akotherm D20 ;)
Nu wordt het zo langzamerhand wachten op de bestelling uit het land van de gele hesjes :)
Ondertussen ook paar proef strookjes gemaakt om te kijken welke beits ik ga gebruiken om ze af te lakken.
Donder walnoot staat op de nominatie.
Lekker bezig!
MechanicalAnimal
yeah!!!!...bouwfoto's altijd leuk, goed bezig Koenjer :goeie: :rock:
Ziet er nu al indrukwekkend uit. Modelletje koelkast.
Prachtig. Begint hier nu ook wel te kriebelen :D
kuiperik
Bericht door kuiperik »
Ziet er goed uit, ook alles netjes dicht gekit zo te zien :goedzo:
Goed voor de gemoedsrust. Maar als je de kast netjes in elkaar zet zal het praktisch weinig uitmaken, Als je een kast 100% luchtdicht maakt (wat niet zal meevallen) heb je een prima barometer gebouwd.
Douwe84
Bericht door Douwe84 »
Lekker bezig hier zeg!
anonamemouse
Bericht door anonamemouse »
Mijn laagkasten zijn 100% luchtdicht, maar ik heb bij veranderende luchtdruk nog niet gezien dat de woofers naar binnen worden gezogen of naar buiten komen puilen.
Dat komt omdat die verandering zo langzaam gaat dat het wel door laat.
OWC
Bericht door OWC »
De tijd variabele heeft hier volgens mij niet zoveel mee te maken.
Maar het echt 100% luchtdicht kregen van een kast is zo goed als onmogelijk.
Zo zijn bepaalde conussen of rolranden toch nog enigszins poreus en heb je toch altijd iets van lek bij schroefgaten of achter de speakerrand. Dat hoeft maar een heel klein gaatje te zijn, drukverschillen zijn namelijk niet ZO groot.
Dat bedoelde ik, een paar millibar per uur is wel max...
OWC
Bericht door OWC »
Oh, excuses, voor mij leek het een beetje alsof enkel tijd belangrijk is.
