ARTA meet software
... is weten!
iemand ervaring hoe snel je je key krijgt na betaling? en heb je dan dat share-it gebruikt of met credit card naar die distributeur?
daniel
Bericht door daniel »
ik heb via ShareIt met IDeal betaald. Was een kwestie van een of twee dagen voordat ik de licensefile binnen had.
Zow hé, die Ivo zit niet stil:
Versie 1.4 is uit met weer een aantal verbeteringen:
http://www.fesb.hr/~mateljan/arta/news.htm
gans
ARTA MessBox, PCB
Bericht door gans »
... maybe interesting for ARTA users:
http://www.visaton.de/vb/showthread.php?t=18203
https://forum.visaton.de/forum/messtech ... ta-messbox
Regards
Heinrich
gans
ARTA 1.7
Bericht door gans »
As every year just before xmas .... :)
ARTA 1.7 will be published on next sunday (probably).
New features in ARTA (extract):
- Mlssa export now without normalization to 1.
- New Mlssa import types (impulse and transient response)
New menu in Imp window:
- Record -> Signal Time Record opens recording dialog with added generator
- Generator in transient recorder generates sine burst and pulse signals
- Generator has new multitone signal for measuring TIM (DIM)
- Periodic square and triangle signals added to ARTA generators
- Copy bitmap string can be saved between opening of dialog
- FR and spectrum graphs with tick marks and more dense grid
- Downsampling (menu Edit->Downsample in Imp window) analysis of CSD in low frequency range.
- Better ISO3382 compatibility in estimation of reverberation time and noise reduction
- Implementation of ASIO INTERFACE to soundcards.
- more simple callibration procedure
- Added overlay plotting in Step response, Dft and IR Envelope windows
- Impedance curve as overlay in FR plot (Imp and FR in one plot)
- Thick line option enabled in all windows.
New in Steps:
- Muting of transients after sine cut-off (at cost of 50% larger measurement time)
- impedance curve overlay in FR magnitude plot
- ASIO interface.
New in LIMP:
- ASIO interface.
Regards
Heinrich
Re: ARTA meet software
carpin
Bericht door carpin »
Hieper de piep :mrgreen:
Een nieuwe versie (V1.71) van ARTA is beschikbaar:
Current version is 1.7.1. released on November, 14, 2011.
http://www.fesb.hr/~mateljan/arta/download.htm
Jah, maar niet veel nieuws :? Kennelijk valt er weinig meer te verbeteren :mrgreen:
satefan
Bericht door satefan »
Kan iemand me vertellen welke microfoon hij/zij gebruikt icm Arta?
grtn
Satefan
grtn
Satefan
Ga je een inventarisatie maken? Er zijn toch heel veel draadjes hier waarin dat naar voren komt...
bartsegers
Bericht door bartsegers »
binnekort kan ik de ECM8000 vergelijken met de geijkte mic van IBF.
(heb exacte de gegevens opgeslagen van de meting met IBF mic, en IBF voorversterker)
Als ik dezelfde speaker meet, zelfde afstand, zelfde versterker, dan krijg ik mooi het verschil te zien.
(wellicht dat ik een calibratiefile kan maken dan voor de ECM8000 ?)
satefan
grtn
Satefan
Nee dat niet. Ik wil eens met Arta aan de slag en niet gelijk een vermogen in een microfoon investeren dus was even op zoek naar een snelle tip zeg maar....
Satefan
En mag het zeker ook niks kosten? :D
bartsegers was met een aardig low-cost zelfmaak ding bezig maar dat heeft ie weer verlaten begrijp ik? Zie hier: http://www.zelfbouwaudio.nl/forum/viewt ... 25&t=14549 Staat ook een link in naar het goedkope zelfbouw ding van Wai
satefan
Tuurlijk mag t wat kosten...maar niet de hoofdprijs...ik ben een beginner op dit vlak :-)
Satefan
Zweitse
Bericht door Zweitse »
Ik ben ook al even aan het zoeken geweest. Misschien dat dit je iets verder helpt.
http://www.zelfbouwaudio.nl/forum/viewt ... 25&t=14652
'Tis wat je wilt, kant en klaar kopen ben je al gauw rond de 100 eu aan kwijt. Het zelfbouwding van Wai tussen de 10 en 20. Moet je dan wel kunnen en zin in hebben. I.i.g. doet kant en klaar gekocht het geen haar beter dan dat zelfbouwdingetje. Als je echt beter dan dat wilt kom je al gauw ver boven de 200 euries uit. Dat heeft eigenlijk voor het zelf bouwen van speakers en filters geen zin.
satefan
Thanks. Wouter hier op t forum die heeft n simpel (maar schijn kan bedriegen) microfoon die rechtstreeks de laptop in gaat...ziet er erg simpel uit. Het is echt om een begin te maken met meten..
grt!
Nou ja, we hoeven niet allemaal meteen een DPA of Earthworks te kopen, of zelfs een Haun of Audix, maar met alle respect, wat is er nou fout aan zo'n ECM8000 als je luidsprekers wilt meten? 't Kapsel heeft een lage eigen vervorming, ruis is redelijk, de relatief lage belastbaarheid is praktisch wel op te lossen en het plug & play is toch ook wel prettig. Je moet alleen wel ff een geluidskaart met 48V regelen. Maar voor de hobby vind ik een investering van 100-200 Euro (ex licentie voor Arta) een lachertje, zeker als je nagaat wat je vroeger kwijt was aan een Neutrik, CLIO of zelfs ATB-systeem.
Dat stelt toch ook helemaal niemand ter discussie? Het is wel duidelijk dat je met een ECM8000 prima uit de voeten kunt. Het gaat er meer om hoe vul je dat verder in. En daar zijn al (bijna :mrgreen: ) eindeloos veel draadjes over gevoerd naar ieder wat wils. Eigenlijk is aan wat daarin allemaal besproken is weinig toe te voegen.
Het dwaalt nu wel erg van het eigenlijke topic af: "ARTA meet software".
bartsegers
ik ben inderdaad gestopt met mn zelfbouw MIC.
Heb de spulletjes wel, maar naast zelf een micje bouwen, komt er meer kijken.
Tevens had ik het geluk tegen een tweedehands setje aan te lopen.
De XLR-USB adapter die ik heb, die tevens 48V fantoomvoeding heeft, ga ik natuurlijk nog eens koppelen aan een zelfbouw capseltje.
satefan
Vandaag een microfoon mogen lenen (degene die bij ATB zit) en eigenlijk gewoon aangesloten, Arta opgestart en de stappen volgens de manual gevolgd. De MIC staat op 40 cm afstand en tussen de woofer en tweeter gericht. Ik krijg onderstaande te zien in Arta:
Nu nog uitdokteren wat het betekent ;-)
Satefan
Chris_T
Bericht door Chris_T »
Hmm volgens mij meet je vooral ruis ^^.
Je kan beter de impulse (IMP) meting gebruiken, 1e marker net voor de puls zetten en 2e marker net voor de 1e reflectie (1e kleine piekje na de pulse).
Je meet dan met een tijdsvenster waardoor je reflecties en dergelijke buiten de meting laat.
@satefan
Laat je setup-menu eens zien! Heb je de samplefrequenties van in- en output gelijk staan? Geen passthrough op de geluidskaart ingeschakeld? Meet je wel met de microfoon (doet hij het met een ander prog of Win 'geluid' wél)?
Satefan
Dat is niet moeilijk: Niegoe :D
Met de Fr1 en Fr2 meting behoor je met periodic noise een dunne responsie lijn te krijgen.
satefan
Net even een IMP gedaan....dit is wat ik krijg:
Er vanuit gaande dat ik een 'deftige' meting heb gedaan lijkt dit aardig te kloppen met wat ik ervaar. De speakerts lijken iets wat 'naar voren' te klinken, nogal 'op je af' zeg maar...
Ik zal deze meting ook even onder het eigenlijke topic plaatsen...
Satefan
