I want to know if the version 10 Neo tweeter can be mated with a simple panel that does all of the mid and lows. this is a scaled down version so power handling and max spl is limited. It also resembles a Mini Magnepan in terms of size and frequencies response. the tension on the foil is much to low since the tape i tried creeped (as always) so it tries to play lower then the xmax allow for. something that would not be present in a MINI Magnepan
https://www.youtube.com/watch?v=2de91zGBAX4
