Test panels Push Pull Planar magnetic (formaat MINI Maggie)
Alles over speaker units
WrineX
Bericht door WrineX »
Playing 2 Chanson's on a test setup. before i go full scale.
I want to know if the version 10 Neo tweeter can be mated with a simple panel that does all of the mid and lows. this is a scaled down version so power handling and max spl is limited. It also resembles a Mini Magnepan in terms of size and frequencies response. the tension on the foil is much to low since the tape i tried creeped (as always) so it tries to play lower then the xmax allow for. something that would not be present in a MINI Magnepan :) the mini would roll of much more early but would have more headroom because of it in the frequencies it can produce. aaah well might refoil it to see what happens.
https://www.youtube.com/watch?v=2de91zGBAX4
floeper
Re: Test panels Push Pull Planar magnetic (formaat MINI Maggie)
Bericht door floeper »
Klinkt Lekker Joppe! ik zou zeggen, Go Big, or Go Home ;)
Klinkt best goed via mijn computerluidsprekertjes. Speelt de muziekkeus natuurlijk ook wel mee.
