Led driver
De rest......
PimDriessen
Re: Led driver
Bericht door PimDriessen »
Hoi Anne,
Ik denk dat je daar gelijk in hebt, moet kunnen dat er een strip wordt kortgesloten.
Maar ja het is mijn lamp niet, dus als het om de een of andere reden niet goed gaat, dan weet mijn verhuurder mij wel te vinden, dan wordt er een pittige rekening geserveerd.
Pim
Toevoeging: Hier staat trouwens wel dat er vanaf 3 leds gewerkt kan worden, had dat nog niet eerder gezien.
[HARVARD TECHNOLOGY]
The CL700S-240-B is Cool-LED - High Power, Switchable LED DRIVERS.
Cool-LED DRIVERS provide a high performance solution for powering high-brightness LED’s from a mains supply. The power factor corrected, class II driver has fully-isolated, SELV output delivering up to 33W of power. The well regulated output current will typically power a series string of between 3 and 12 LEDs with a 1W to 3W rating up to a combined forward voltage of 48V. High efficiency design ensures cool operation and long life. The compact enclosure is available in Integral (B) and Remote Mount (C) versions. Remote types feature screwless cable clamps. Cool-LED DRIVERS are open and short-circuit
protected and have self-resetting over temperature trip. Cool-LED DRIVERS feature a switch, accessible during installation, to select between full and half rated output current. Consult the sales office for versions where the current level can be set by external switch or presence detector. These drivers include a “soft dim” feature to avoid sudden steps in LED brightness.
Key Features:
Mains input voltage range 198 to 265 VAC rms.
Mains frequency 48 to 62 Hz.
Power factor at full load >0.95 (0.98 typical).
Efficiency at full load 88% typical.
Power factor corrected (0.98).
Constant current output.
Switchable between 350/700 mA or 500/1000 mA.
Self resetting Thermal Trip.
Double insulated (Class II)
Screwless cable clamps for fast assembly.
Up to 89% efficient.
Surge protection up to 4 kV.
IP40 rated enclosure.
Dimmable versions available.
SELV Isolation.
Integral and Remote versions.
Made in UK.
Re: Led driver
Klopt, elke strip heeft drie led's dus 3 ...12 led's = 1 ... 3 strips.
De hier gebruikte led heeft een wat kleinere spanningsval dan gangbaar, is rond 3,6V en hier <3V !
Eén strip komt dan onder 9V, eigenlijk net te weinig.Zal wel niet kapot gaan maar met wat minder stroom genoegen moeten nemen.
PimDriessen
Re: Led driver
Hoi Anne,
Maar hoe kan het dan dat de 48 volt die aangegeven staat in de specificaties niet gehaald wordt, want als er toch maar 25 volt staat zouden 2 led strips toch ook moeten kunnen?.
Desnoods een weerstand in serie?. :think:
Pim
Re: Led driver
De voeding is een constante stroombron. Die houdt de stroom constant en past de spanning aan naar wat de leds vragen. Maar hoger dan 48V kan ie niet.
PimDriessen
Re: Led driver
Hoi Pjotr,
Het is ook nog niet duidelijk of er op dit moment met 3 led strips 350 mA wordt getrokken door de leds.
Het is misschien zinvol om dat te gaan meten met een stroommeter, want als het minder is dan 350 mA is het overbruggen van een van de led strips toch mogelijk, wat denk jij?.
Pim
Re: Led driver
Ja, maar zou ze niet allemaal overbruggen...
PimDriessen
Re: Led driver
Hoi Pjotr/ Anne,
Wat een Poppenkast al die specificaties van 350/700 mA, er loopt op de stand half vermogen 65 mA, gemeten bij 25 volt DC.
Ook nog een idee om aan de helft van het licht te komen.
Foto lamp zoals hij geplaatst is,
Lamp op de nieuwe manier geplaatst licht staat uit, lamp staat aan in nieuwe stand.
Pim
Re: Led driver
PimDriessen schreef:
Hoi Pjotr/ Anne,
Klopt iets niet, mag kiezen, voeding of meting mis :-s
Ook een oplossing, over rendement zullen we maar niet hebben :lol:
PimDriessen
Re: Led driver
Hoi Anne,
Ik keek er ook van op, maar de meter geeft echt 65 mA aan, meter bereik stond op 400 mA.
En eerder de 25 volt klopt ook echt.
Zijn dit niet gewoon leds met een soort lens, zag dit pas weet niet meer waar of bij wie, was 12 of 24 volt en ook lage stroom.
Pim
Re: Led driver
Hoi Anne,
Groet,Pim
Welke led of wat er dan ook aan zo'n voeding hangt, er moet de opgegeven stroom lopen.
Met iets eraan waardoor er maar 65mA wil zal de spanning naar 't max doen stijgen, de voeding doet alle moeite om er toch de gewilde stroom door te krijgen.
Hang er 's een weerstand aan ipv de led's, iets van 100 ohm en meet de spanning.
Met 65mA krijg je dan maar 6,5V (te laag voor die voeding) maar als de voeding goed is krijg je 350mA x 100 ohm = 35V (wel ruim 10W in de weerstand dus een dikke of heeel eventjes)
PimDriessen
Re: Led driver
Hoi Anne,
Nu met de zelfde meter als bij de stroommeting vanmiddag 65 mA, de spanning gemeten die op de uitgang van de led driver staat.
Pim
Hier de info over de COB Led plaat.
Re: Led driver
Je meet spanning en stroom bij een onduidelijke voeding en een onduidelijke belasting.
Om wat vastigheid te hebben vroeg ik om 's te meten met een bekende weerstand.
Is er tenminste één deel van de meting zeker.
PimDriessen
Re: Led driver
Hoi Anne,
Om voorzichtig te beginnen en uit te gaan van de specificaties 48 volt, begin ik met 440 ohm en als dat goed gaat met 270 ohm.
Want ga er vanuit dat de voeding 48 volt kan zijn.
En om het niet al te ingewikkeld te hoeven doen, meet ik over de weerstand die op dat moment aan de voeding hangt.
Laat het binnenkort zien.
Pim
Re: Led driver
Je moet onder de 137Ω blijven anders heb je meer dan 48V nodig om 350mA te halen !
Met te grote weerstand loopt de spanning naar het max haalbare, volgens het verhaal erbij 55V.
PimDriessen
Re: Led driver
Hoi Anne,
Dat is niet helemaal waar, het is maar 2 volt, hier de resultaten.
440 ohm aan de voeding zonder leds, 50 volt over de weerstand = 113 mA 5,68 watt.
270 ohm aan de voeding zonder leds, 50 volt over de weerstand = 185 mA 9,25 watt.
Ga daar maar geen weerstand van 137 volt aan hangen dat wordt dan 364 mA.
Uit het bovenstaande kan maar een conclusie gelden de leds strips laten de voeding in elkaar storten zodat daar nog maar
60 mA overblijft ?.
Pim
Re: Led driver
Je haalt de 350mA zo niet, gevolg de spanning blijft boven de 48V.
Nee, dan zou er 350mA moeten stromen met als gevolg 137 x 0,35 = 47,95 volt.
60 mA overblijft ?
Als een stroombron "instort" is dat met een te kleine belasting zodat ie niet voldoende spanning meer kan leveren om de bedoelde stroom te bereiken.
In feite is een stroombron 't minst belast met kortsluiting.In dit geval heeft de schakeling die de stroombron maakt minimaal 9V nodig om te werken.
Zoiets als een gestabiliseerde spanning die een minimale stroom nodig heeft om te werken.
PimDriessen
Re: Led driver
Hoi Anne,
Wat kan de conclusie zijn van deze meting ?.
Is het mogelijk om een led te overbruggen mogelijk met een weerstand in serie om minder licht te krijgen ?.
Wat doen die leds dat de voeding 25 volt wordt en maar 60 mA trekt ?.
Daar begrijp ik niets van. :think:
Ik hoop dat je het me uit kan leggen.
Pim
Re: Led driver
Hoi Anne,
Dat de voeding 't vermoedelijk wel doet.
Hoe een led te overbruggen met een serieweerstand ontgaat me :-s .En serieweerstanden veranderen de stroom niet, de spanning loopt op om weer dezelfde stroom te krijgen.
Daar snap ik ook niks van, klopt gewoon niet.
Daarbij, de led's trekken geen 60mA, er wordt stroom opgedrongen met een spanningsval tot gevolg.
PimDriessen
Re: Led driver
Hoi Anne,
Dat kan inderdaad de conclusie zijn de voeding doet het. :!:
Ik bedoelde een led loshalen en daarvoor in de plaats een weerstand om minder licht te krijgen.
Ik heb dat toch goed gemeten, stroommeter tussen de + draad en de schakeling aangezet.
Dat komt niet vaak voor dat jij het niet duidelijk krijgt. :-#
Maar dan de brandende vraag kan de lichtsterkte nog omlaag op de een of andere manier, nu hebben de meeste mensen mijn idee wat als grap begon nagebootst en zijn zeer enthousiast. :sure:
Pim
MFBass
Re: Led driver
Bericht door MFBass »
Ik denk dat je 1 van de 3 leds kunt vervangen door een weerstand van 0 Ohm. Da's de makkelijkst optie.
Die support gast die zei dat het niet kan heeft het gewoon niet helemaal begrepen.
Re: Led driver
Tja, een weerstand van 0 ohm of kortsluiten, blijft een moeilijke keus :?
Zo raakt Pim nog meer in de war :( :lol:
MFBass
Re: Led driver
Hihi, sorry. Ik nam aan dat Pim dat nog wel snapt :)
PimDriessen
Re: Led driver
Hoi Anne/MFBass,
Bedankt heren, ja dat snapt Pim nog wel [-( :-k
Kortsluiten is niet mijn idee van uitproberen zou toch eerst met een weerstand van 220 ohm beginnen om te kijken wat er gebeurt.
Nogmaals het hangt aan mijn buitengevel, dus het is niet iets was op mijn werktafel ligt waar je mee aan het experimenteren bent, dus wat is nu ineens de zekerheid dat er een led overbrugt kan worden ?.
Terwijl dat al die tijd een vraagteken was ?.
Pim
Re: Led driver
Huh ? Niet enkel één led, maar zelfs
Berichtdoor Ah!buis » do 17 mei 2018, 21:07
Je mag gerust één strip weglaten (of kortsluiten) brandt de boel op 16,5V.
MFBass
Re: Led driver
Hi Pim,
Ik had niet eerder gereageerd, maar mij was het meteen duidelijk (en Anne had het wel al gezegd). Je hebt ca 8V per led. 3 LEDS = 24V.
2 LEDS = 16V, nog steeds meer dan het minimum van de voeding.
1 LED = 8V, da's te weinig.
Bij de 8V per led, en 350mA, zou je een LED kunnen vergelijken met een weerstand van 8/.35 = 23Ohm.
Als je één led 'overbrugt' met 220 Ohm, doet dat precies niets dus die test hoef je niet te doen.
Vervang dan 1 led door een weerstand van 22Ohm. Wel een 5W modelletje nemen. Stook je wel een paar watt voor nop. Daarom nog beter gewoon 1 led overbruggen.
David
