http://www.xilica.com/docs/XD_Manual_v0203.pdfNumber of FIR Taps for each pair of output channels (ie. Output 1&2,
Output 3&4, Output 5&6, Output 7 and 8 ).6 The sum of all taps cannot exceed
1500 and maximum taps per pair is 1200.
For FIR filters, the higher the taps, the higher the slope in dB for the same
frequency, or the lower frequency the FIR can handle for the same slope.
Generally speaking, higher frequencies require smaller number of taps, and
lower frequencies require higher number of taps. For good steepness for
FIR crossovers:
(tabelletje)
# of Taps Minimum Frequency (Hz)
50 4800
100 2400
150 1600
200 1300
250 1000
300 850
350 700
400 625
450 550
500 500
550 450
600 425
650 400
700 390
750 385
800 340
850 310
900 285
950 275
1000 265
1050 250
1100 230
1150 220
1200 210
Als ik het goed begrijp heb je dus weinig aan deze filters in het laag bereik (<200hz), want bij 210 hz zit je al aan het max van 1200 taps (what ever that may be)
Klopt dat of zie ik het verkeerd?
