http://www.pacificvalve.us/BDHD19.htmlomschrijving schreef:The elegant design of the HD-19 uses proven high-quality
Sony laser optics and the same Phillips servo circuitry as
found in the HD-22. Digital to analog (DAC) conversion is
through a 96 kHz 24 bit Burr-Brown PCM1732 respected
chipset manufacturer is coupled to an audiophile grade
6N3/5670 output tube or, if you prefer, an OP AMP buffer
plaatje binnenkant:
