Meerdere chassis gebruiken zonder grote filterverandering ?
Geplaatst: di 15 mei 2007, 19:03
Hoi zelfbouwers,
Ik vroeg mij af of je zomaar een drieweg ontwerp met een woofer,midden en hoog kan aanpassen door hiervoor twee laag en midden weergevers te gebruiken ?
Hierbij dacht ik aan een D,appolitio opstelling.
Een uitleg hierover vind je wel op internet maar werkt dit ook zondermeer ?
Groet Peter
D'Appolito Crossover Calculator
the reverse calculator is
also available
This calculator was developed to help our customers to change a standard 2 way system (1 tweeter + 1 bass driver) into a 2 way system with 2 bass drivers that are often surround the tweeter (D'Appolito arrangement).
Now the question arises: how to change the crossover?
Regarding the bass driver:
That part of the crossover that serves the bass drivers needs to be changed as follows:
- the coils' inductance needs to be halved (therefore, 2 coils are in parallel)
- the capacitors' capacitance needs to doubled (therefore, 2 capacitors are in parallel)
- the resistance values need to be halved (therefore, 2 resistors are in parallel)
Please bear in mind:
The coils should have a wire diameter that is 1.4 to 1.5 bigger.
The resistors should have double the load-carrying ability.
Regarding the tweeter:
That part that serves the tweeter remains unchanged with regard to coils and capacitors.
However, the output of the tweeter needs to be increased by 6 dB. To achieve this the resistors have to adapted. The picture below shows on the left how a system with one bass driver should look like, and on the right how it should look like with 2 bass drivers. Just enter the impedance of the loudspeaker and the values of the two resistors on the left and click calculate.
2 way loudspeaker with
one bass driver
D'Appolito Level Calculator
High Frequency Circuit
2 way D'Appolito
with 2 bass drivers
Impedance of loudspeaker:
Ohm
Please enter decimal separators as "."
Serial resistance Rs: Ohm Serial resistance Rs: Ohm
Parallel resistance Rp: Ohm Parallel resistance Rp: Ohm
Damping: dB Notes regarding the result: Damping: dB
Total impedance: Ohm Total impedance: Ohm
further hint: Please choose a resistance with adequate load-carrying ability.
Copyright © Iris Strassacker, 2002. All rights reserved - Warranty excluded
Print this page Home
Groet Peter
also available
one bass driver
2 way D'Appolito
with 2 bass drivers
Ohm
