Meerdere chassis gebruiken zonder grote filterverandering ?
peterlegina
Bericht door peterlegina »
Hoi zelfbouwers,
Ik vroeg mij af of je zomaar een drieweg ontwerp met een woofer,midden en hoog kan aanpassen door hiervoor twee laag en midden weergevers te gebruiken ?
Hierbij dacht ik aan een D,appolitio opstelling.
Een uitleg hierover vind je wel op internet maar werkt dit ook zondermeer ?
Groet Peter
D'Appolito Crossover Calculator
the reverse calculator is
also available
This calculator was developed to help our customers to change a standard 2 way system (1 tweeter + 1 bass driver) into a 2 way system with 2 bass drivers that are often surround the tweeter (D'Appolito arrangement).
Now the question arises: how to change the crossover?
Regarding the bass driver:
That part of the crossover that serves the bass drivers needs to be changed as follows:
- the coils' inductance needs to be halved (therefore, 2 coils are in parallel)
- the capacitors' capacitance needs to doubled (therefore, 2 capacitors are in parallel)
- the resistance values need to be halved (therefore, 2 resistors are in parallel)
Please bear in mind:
The coils should have a wire diameter that is 1.4 to 1.5 bigger.
The resistors should have double the load-carrying ability.
Regarding the tweeter:
That part that serves the tweeter remains unchanged with regard to coils and capacitors.
However, the output of the tweeter needs to be increased by 6 dB. To achieve this the resistors have to adapted. The picture below shows on the left how a system with one bass driver should look like, and on the right how it should look like with 2 bass drivers. Just enter the impedance of the loudspeaker and the values of the two resistors on the left and click calculate.
2 way loudspeaker with
one bass driver
D'Appolito Level Calculator
High Frequency Circuit
2 way D'Appolito
with 2 bass drivers
Impedance of loudspeaker:
Ohm
Please enter decimal separators as "."
Serial resistance Rs: Ohm Serial resistance Rs: Ohm
Parallel resistance Rp: Ohm Parallel resistance Rp: Ohm
Damping: dB Notes regarding the result: Damping: dB
Total impedance: Ohm Total impedance: Ohm
further hint: Please choose a resistance with adequate load-carrying ability.
Copyright © Iris Strassacker, 2002. All rights reserved - Warranty excluded
Print this page Home
Nee.
De behuizing en het filter van een driewegsysteem is berekend en geoptimaliseerd voor dat driewegsysteem. Als je er een extra woofer en middentoner bij wil zetten zul je de behuizing en het filter opnieuw moeten ontwerpen. Ook is het maar de vraag of het rendement van de tweeter nog wel hoog genoeg is om even luid te spelen als twee middentoners.
Maar wat moet dat engelstalige gebrabbel onder je post?
Laatst gewijzigd door richard op di 15 mei 2007, 19:18, 1 keer totaal gewijzigd.
Edo
Mede-oprichter ZBA
Bericht door Edo »
Idem hier. Kort misschien, maar antwoord is nee.
Zijn toch wel verschillende dingen met wat andere filters etc.
peterlegina
Nou hierin wordt dus uitgelegt hoe je een systeem met een laag / midden zou moeten aanpassen naar een systeem met dubbel laag / midden.
dus vandaar de vraag of dit in de praktijk zo zou moeten werken
.http://www.lautsprechershop.de/english/index_tools.htm
groet Peter
onder vooraarden zou nog wel eens kunnen denk ik, kast wordt hoger, niet breder.
tuurlijk, echt optimaal is t niet en een echt voor de d'A gemaakt filter doet t altijd beter, maar een aardig end in de richting komt t wel. Strassacker zou t niet op z'n site zetten als het een slecht resultaat zou leveren....
Speakerland
Bericht door Speakerland »
Als je een d'Appolito opstelling vergelijkt met een gewone 2-weg opstelling zijn er veel meer verschillen dan dat je kunt oplossen door simpelweg even de waarden van de spoelen te halveren en die van de condensatoren te verdubbelen.
Er onstaat namelijk een heel ander afstraal en fase gedrag.
Ruud Jansen
Speakerland
peterlegina
ok ik snap het, dus gewoon niet zelf aan gaan beginnen
