Te koop Holton NXV500r2
Geplaatst: zo 14 apr 2024, 15:45
Te koop :
1 Holton HPA- NXV-500-r2 module
Zit nog werkend in een behuizing
vraagprijs : 150 Euro
300 Watts RMS continuous sine wave into 8 Ω
500 Watts RMS continuous sine wave into 4 Ω
The HPA-nxV500 R2 is 2 Ω Stable
Biased into Class A/B
Power Bandwidth 3.5hz to 250khz -3dB
Slew Rate = 80v /uSec
Dampening Factor At 100hz 8Ω = 1300
RCA Single ended Input impedance 20kΩ
Differential Input Impedance = 40kΩ
Rail voltage max. +- 78Vdc
Front end rail voltage max. +-85Vdc
