Nu dus graag alleen nog over de plate amps.
Hypex Fusion Plate amps
- Marp
- Beheerder / Sysadmin
Re: Hypex Fusion Plate amps
Op veler verzoek is het draadje opgeschoond.
De ADAU1452 lijkt ook FIR filters te ondersteunen. Wordt dit straks ondersteund?
Kon je bij filter design nu ook presets kopieren? Ik kon dit niet vinden in de handleiding
Dus dat kan nu nog niet?
Ik wil bijvoorbeeld preset 1 en 2 exact gelijk, alleen verschillend volume.
Maar dat wordt dus apart invoeren.
Oke, dankjewel.ds23man schreef:Op dit moment niet nee.
Erg mooi, dat het er wel in gaat komen.
De configuratiefile die op je pc wordt opgeslagen is een XML bestand. Daar zou je in kunnen knippen en plakken als je exact weet wat je doet.
Any more updates from our friendly neighbourhood Hypex guru? I'm gearing up for international distribution of flatpack DIY speaker kits of the highest quality that will utilize these plates. Still hoping Hypex decided to sneak in some nice surprises for us
To all the enthusiasts of the new Hypex Fusion Amp,
The interest in our new Fusion Amps rises every week, often we get questions about them and all the enthusiasts can’t wait for the release of this new plate amplifier range, including ourselves. In our earlier communications we announced the launch of the new Fusion Amp range in the third quarter of 2017 but we need to postpone the launch to the first quarter of 2018.
And now the good news! We like to announce a new feature for the complete Fusion Amp range. We will add an option to ensure the Fusion Amp can also be operated with remote control for volume control and source selection. Our well known Hypex Remote Control can be used for these purposes. The IR receiver will be a loose part so our customers can integrate this when needed and where needed. This feature was widely asked and with this implemented in the Fusion Amp we hope to meet your needs.
You have received this email because you’re noted in the mailing list for the new Hypex Fusion Amp, because you’re an enthusiast we would like to receive a reply with your preference within this new range. An updated preliminary info sheet can be found enclosed.
Kind regards,
Sales Team | Hypex Electronics B.V.
Kind regards,
I just got that message in an email from Hypex. But no mention of the DSP upgrade. I just replied and asked if AOIP will be an option in the OEM solution. If not we are building our own DSP based plates with the MP series amps with Ravenna input as our budget option.
Well this is what I heard:
Chip specifications:
DSP: ADAU1450 using external ADC en DAC
ADC: 192kHz 24-Bit Enhanced Dual Bit ADC
SRC: AES/EBU –S/PDIF 192kHz 24-Bit
DAC: AK4454 768kHz 32-Bit
DSP filters: 3x15 Biquads
No Dante in any product. DIY or OEM. So I guess someone on this thread is starting rumours
Probably a good choice to go for the AK4454. The "Velvet Sound" filters are soft and pleasant. So will be welcome when connecting direct to amps and drivers, as there's no means to voice with passive crossovers to soften the sound. Better to lean towards a bit of softness rather than hard and analytical.
- anonamemouse
Uhm... Nee.ds23man schreef:
"Are you well good by your head" zijn allemaal goede Engelse woorden, maar het is geen correct Engels. Zie ook mijn bericht op pagina 1 waar ook niets mee gedaan is.
