Concaeve SATelite
mike
Re: Concaeve SATelite
Bericht door mike »
Hopefully your are MAC-users, because then you have Perl installed out of the box :wink:
On windows you have to install the script/programming language Perl (http://www.perl.org/) first.
There are two Perl scripts (arta2atb.pl and atb2atb_corr.pl), one example measurement (atb file left.txt) and a calibration file (ECM40_VS.cal).
If you want to correct the ATB measurement with the calibration file, then open a shell/terminal, navigate to
the folder where your scripts are and type:
./atb2atb_corr.pl left.txt ECM40_VS.cal > left_corr.txt
This will generate a left_corr.txt - file with the calibrated data.
If you want to take your ARTA output so it can be loaded into your TDA, then do a:
./arta2atb.pl arta_output.csv > atb_file_for_tda.txt
Have fun with the tools!
Converters.zip
(14.82 KiB) 61 keer gedownload
BertDB
Bericht door BertDB »
mike,
what amplifier do you have?
The older TDA 2200 or the newer integrated TDAI 2200 ?
Thanks for sharing your knowledge and your program.
I think I'll buy the ATB PC PRO version so I can do some development myself too.
I red somewhere in the manual that they get around 'time windows' on a clever way so you can do room analysing very well. Is that correct?
Past week, I (finally :D) treated my cabinets with the Lignal beitz and varnish.
I am surprised about the quality of the 2-component Pura Natura (in a positive way).
Altough not cheap, I will definitely use it for future projects and can recommend it to anyone. (39€ for 0,9L varnish and 0,1L hardener)
Offcourse, Ed's cornerwoofers (coming soon :D) will be done identically at these Rapides (help, more veneerwork :shock: :D)
@ fluppie
I saw your test of different measurement microphones.
I can assume the atb mic is quite good. But can I use it with my onboard soundcard (creative thing) or do I need an external one? (like M-audio).
mike
Bericht door mike »
I own an old TDA from the first series. Bought it used. I cannot install RoomPerfect Module
without changing the motherboard. That's why I know it is an older one.
ATB works very well for room corrections. Do not know if the Pro version offers loading a file for
microphone correction. The normal version (ATB PC) does not offer the loading of a correction file.
That's why I implemented the Perl scripts.
The SATelite work at the moment with my self-built corner woofers (MDF sandwich construction with lead sheet).
Excellent sound quality. Did not expect such a good quality of sound when I started the whole project. I am very pleased.
The sound completely uncouples from the speakers. An awesome 3D experience!
