diy ipod docking?
diy ipod docking?
zijn die er al?
Re: diy ipod docking?
misschien zelf maar eens wat proberen te maken....
Apple iPod, iPhone (2g, 3g), iPad Dock connector pinout connector or cable wiring scheme
bookmark this page
30 pin iPOD proprietary connector
at the player ( white side up)
Used in 3rd and later generation iPods for charging, connecting to a PC via USB or Firewire, to a stereo via line-out, to a serial device (controlled via the Apple Accessory Protocol). This connector exists in most Apple iPod MP3 players (iPod 3G, 4G, 5G Video, 5.5G Video, Nano (1G, 2G, 3G, 4G), Mini, Classic, Touch, Touch 2G, and iPhone (1G, 3G and 3GS))
Pin Signal Description
1 GND Ground (-), internally connected with Pin 2 on iPod motherboard
2 GND Audio & Video ground (-), internally connected with Pin 1 on iPod motherboard
3 Right Line Out - R (+) (Audio output, right channel)
4 Left Line Out - L(+) (Audio output, left channel)
5 Right In Line In - R (+)
6 Left In
Line In - L (+)
7 ?
8 Video Out Composite video output (only when slideshow active on iPod Photo)
or Component Video Pb
9 S-Video Chrominance output for iPod Color, Photo only
or Component Video Y
10 S-Video Luminance output for iPod Color, Photo only
or Component Video Pr
11 AUDIO_SW If connected to GND the iPhone sends audio signals through pin 3-4, otherwise it uses onboard speaker.
12 Tx ipod sending line, Serial TxD
13 Rx ipod receiving line, Serial RxD
14 RSVD Reserved
15 GND Ground (-), internally connected with pin 16 on iPod motherboard
16 GND USB GND (-), internally connected with pin 15 on iPod motherboard
17 RSVD Reserved
18 3.3V 3.3V Power (+)
Stepped up to provide +5 VDC to USB on iPod Camera Connector. If iPod is put to sleep while Camera Connector is present, +5 VDC at this pin slowly drains back to 0 VDC.
19,20 +12V Firewire Power 12 VDC (+)
21 Accessory Indicator/Serial enable Different resistances indicate accessory type:
1kOhm - iPod docking station, beeps when connected
10kOhm - Takes some iPods into photo import mode
6.8 kΩ - Serial port mode. Pin 11-13 are TTL level. Requires MAX232 chip to convert to RS232 levels.
68kOhm - makes iPhone 3g send audio through line-out without any messages
500kOhm - related to serial communication / used to enable serial communications Used in Dension Ice Link Plus car interface
1MOhm - Belkin auto adaptor, iPod shuts down automatically when power disconnected Connecting pin 21 to ground with a 1MOhm resistor does stop the ipod when power (i.e. Firewire-12V) is cut. Looks to be that when this pin is grounded it closes a switch so that on loss of power the Ipod shuts off. Dock has the same Resistor.
22 TPA (-) FireWire Data TPA (-)
23 5 VDC (+) USB Power 5 VDC (+)
24 TPA (+) FireWire Data TPA (+)
25 Data (-) USB Data (-)
26 TPB (-) FireWire Data TPB (-)
27 Data (+) USB Data (+)
Pins 25 and 27 may be used in different manner. To force the iPod 5G to charge in any case, when USB Power 5 VDC (pin 23) is fed, 25 must be connected to 5V through a 10kOhm resistor, and 27 must be connected to the Ground (for example: pin 1) with a 10kOhm resistor.
iPod 5G can also be forced to charge by attaching the data + and the data - pins to the 5v via a 10k Ohm resistor ( BOTH PINS) and connecting pin 16 to the 5v (ground). (Confirmed working with iPod 5G 20GB). This provides 500mA of current for charging. For quicker charing, up to 1A, see below.
To charge an iPhone, 3G, 3GS, 4 / iPod Touch, 2nd gen, 3rd, 4th or Ipod Classic (6th Gen), usb data- (25) should be at 2.8v, usb data+(27) should be at 2.0v. This can be done with a few simple resistors: 33k to +5v (23) and 22k to gnd(16) to obtain 2v and 33k to +5v and 47k to gnd to obtain 2.8v. This is a notification to the iphone that it is connected to the external charger and may drain amps from the usb.
To charge iPod Nano pins 25 and 27 should be tied together and then connected to a 10K ohm resistor, and the other side of this resistors then needs to be connected to 5v power.
It's also possible to charge the iPod's or iPhone's battery to make use the of internal +3.3v output (18) terminal to connect the USB Data + (27) thru a 47k ohms resistor and the USB Data- (25) thru a 47k resistor to the USB Power source +5v (23). This way the USB function is still useable for normal operations and makes it easier the fit in a plug. The resistors are not to critical 2x 150k's still work.
28 TPB (+) FireWire Data TPB (+)
29,30 GND FireWire Ground (-)
Back side of dock connector;
2 4 6 8 10 12 14 16 18 20 22 24 26 28 30
1 3 5 7 9 11 13 15 17 19 21 23 25 27 29
Pins 1,2 connected on motherboard.
Pins 15,16 connected on motherboard.
Pins 19,20 connected on motherboard.
Pins 29,30 connected on motherboard.
If you disassemble the original apple-ipod-dock-connector-cable and look at the connector itself, on the back side, where it is soldered, you can see the number 1 and 30 (e.g. pin 1 and 30). In this description NUMBERING is INVERSED: pin 1 is pin 30 and pin 29 is pin 2, so, don't look at numbers on connector.
The remote control, iTalk and other serial devices use Apple Accessory Protocol for communication with iPOD. This protocol was introduced with the 3rd generation iPods, and is also compatible with the 4th generation iPods and mini iPods. The connections uses a standard 8N1 (one startbit 8 data bits 1 Stopbit) serial protocol, 19200 baud (higher rates up to 57600 also possible, but speed faster than 38400 may cause problems with large amounts of data), delay of 12 microseconds inserted between end of the stopbit and the beginning of the next startbit (also working without this delay).
Electrical: high +3,3V low 0V
default line state: high. Codes used for communication with peripherals are here
This device may be connected to the firewire computer port by straight cable (TPB+/-, TPA +/- should be twisted pairs in cable)
iPod Nano 4th Gen no longer will charge from 12 volts on the firewire pins. If you tie pins 25 and 27 together and then connect a 10K ohm resistor to +/- 5 volts to pins 23 and 15 (or 16) then it will charge. If you don't tie 25 and 27 together, it won't charge.
iPod Touch 3G: may also require for pins 1 and 2 (GND and audio out GND) to be connected in order to output audio (pin 11 to GND). Works with appr. 500 kOhm between pin 21 and GND.
iPod Touch 2G requires pin 11 connected to 15/16, then connect that to pin 21 with a 68kOhm resistor to use the audio line out. This is because the device needs to be told to redirect the signal to the Line Out pins rather than to the built-in speaker. This explains why certain accessories won't work with the iPod Touch 2G and maybe even the iPod Touch 3G. The Nano 5G will require the pin 11 connection but not the 68kOhm resistor for redirecting audio.
Nano 5G: connecting the 68kOhm resistor to ground will disable the audio redirection accomplished by connecting pin 11 to ground.
You may need to ensure 1 and 2 are connected to GND for proper charging to occur.
Ik meen dat Pjotr er weleens mee bezig geweest is... Waar wil je die connector vandaan halen ? een docking slopen ? :lol: :lol:
waarom niet?
die koop je al voor heel weinig.
dan een goed dacje,kastje.....
kun je al bijna een wadia i170 kopen! :lol:
Waarom een dac in een kastje? Er zit een dac in je iPod, maak je daar toch een mooi carbon kastje om :twisted: :mrgreen:
B.t.w. Ik ben bezig geweest met om de line in aan de praat te krijgen om hem als recorder te gebruiken, dat ging dus niet. Die line in zit nog wel op de docking connector maar Apple was zo rot om die functie firmwarematig te disabelen vanaf de G3 series.
Als je zelf een docking station wilt maken kun je het beste een docking station kopen voor een paar $ bij DealExtreme. Een losse docking kabel kopen bij ze heeft weinig zin, Daarvan zitten niet alle pinnen er in.
ik weet niet of jij de dac uit zo`n docking wel eens aanje set hebt gehangen......
maar daar doe ik het niet voor! :mrgreen:
Je bedoelt zo'n Wadia? Antwoord: Nee. Maar waarom zou je MP3 over een dure Wadia dac willen afspelen? Kun je beter gelijk naar een SB Touch gaan, die speelt tenminste ook Flac af.
In een goedkoop docking station zit helemaal geen dac, alleen wat connectors naar de line out van de iPod.
Die dac in de iPod Touch zelf (ik heb een een G4) is verrassend goed vind ik. Maarreh ik gebruik mijn iPod eigenlijk alleen als remote voor mijn knijpdoos :lol: En verder onderweg en in de tuin in mijn luie stoel :mrgreen:
de touch heb ik ook!
maar ik wil `m gebruiken voor de amp op m`n werktafel.
dan hoef ik niet elke keer alles op m`n gewone set aan te sluiten,maar het moet wel een beetje klinken.
De dac in de iPod is gewoon goed. Gewoon een line out kabeltje en/of goedkoop docking geval bij DealExtreme bestellen.
ben benieuwd,zal eens zo`n kabeltje op m`n werk bestellen!
Jah, en er zijn zat appjes om vanaf je server via WiFi te streamen als je daarop e.o.a. DLNA server hebt draaien. Alleen Flac vertikt ie dan. Er is wel een appje om je Squeezeserver te gebruiken: "Squeezecast", dat speelt wel Flac af vanaf de sever (maar geen Hi-res Flacs) :mrgreen:
Lees de reviews en check of die kabeltjes ook werken met jouw iPod. Ik heb er een paar die het NIET doen met mijn Touch 4. Kun je beter gelijk zo'n dock'je bestellen met line uit.
ik wil geen knijpkast!
er staat al een sonos zp90+nas klaar :wink:
en daar moet nog een mooie dac bij komen.
Oh, en ik maar denken dat je docking voor je iPod wilt klussen.
Ze zegt zelf dat je een SB Touch hebt ??? Zonder een Squeezeserver op je NAS/server heb je daar weinig aan. Of je moet alleen muziek afspelen van een SD kaartje/USB schijfje.
Met dat app'je maak je van je iPod i.d.d. een SB, dat is alles. Dat is leuk om er bij te hebben maar dat hoef je natuurlijk niet doen.
ik wil `m gaan gebruiken om even een stukje muziek af te spelen op m`n werkbank,dus icm een nog te bouwen kleine buizen pre,de zappulse 2.3se en dan een goed klinkende ipoddock of misschien gewoon een usb dac....
zoveel plannen...... :mrgreen:
