Ik ga naar China en neem terug???
Ik zit eraan te denken om een DAC tijdens mijn vakantie te kopen in China.
Iemand ervaring met onderste twee DAC's?
HLLY HIGH END DMK-IV DAC + HP amp (1680 Yuan)
1. USB, Coaxial, Optical DAC
2. Analog Pre-amplifier
3. Analog/ Digital Headphone amplifier
4. High quality Sounds (AD797 & Good design Circuit)
5. Top Grade VFD Displayer
1. Standard input connector: SPDIF, Coaxial, USB, Analog Input (CMC RCA connectors).
2. Input Frequency: 44.1,48,96KHz/16/24Bit auto-recognized.
3. SNR: >115Db.
4. Dynamic Range: 110Db.
5. THD+N: 1KHz%0.0006.
6. Frequency response: 20-20KHz.
7. DAC power:<18W.
8. Headphone out power: 300R/300mW.
9. Dimensions: 200*310*60mm.
10.Weight: 2.6 Kg.
11. Packing Size: 320 * 230 * 120mm
Matrix Mini-i Balanced DAC+ HP amp (1980 Yuan)
D/A DAC chip AD1955 x 2
Full balanced stereo design
Up to 24Bit/192kHz sampling
USB input works with Windows 2000/XP/Vista/7 and Mac OS 10.x, no extra driver needed
Pre-Amp/HP-Amp and Pure DAC modes switchable
Low jitter receiver chips and separate clock
Built-in headphone amplifier, for up to 300 ohm headphones
OP275/OPA2134 op-amps NOT replaceable
Balanced/Unbalanced outputs
Various inputs: BNC/RCA/Toslink/AES/EBU/USB
Large screen LCD display
Designed and fine tuned for audiophile
Digital input pass-through via an RCA output, easy connect to another receiver
Analog Interface:
- RCA/XLR
- Frequency Response: 20-20kHz
- Signal to Noise Ratio: 105dB
- Dynamic Range: 108dB
- Distortion 0.0002% (1kHz)
Digital Input:
- Optical: toslink, 32K to 192kHz
- Coaxial: 75 ohm RCA/BNC, 32 to 192kHz
- USB: USB-B, 44.1-48kHz
- AES/EBU: Standard XLR balanced, 32-192kHz
Digital Output:
- Coaxial RCA
- 32-192kHz
- Support AC3/DTS Pass Through
Power Support: AC 220-240V or 110V
Front Panel Color: Silver
Case Color: Black/Silver
Weight: 2 kg
Device Dimension: 205 x 155 x 48mm (L x W x H)
3. SNR: >115Db.
7. DAC power:<18W.
10.Weight: 2.6 Kg.
Analog Interface:
- RCA/XLR
Digital Input:
Digital Output:
- Coaxial RCA
- 32-192kHz
Weight: 2 kg
Laatst gewijzigd door DKM op di 28 jun 2011, 8:27, 1 keer totaal gewijzigd.
Re: Ik ga naar China en neem mee???
die matric lijkt wel erg veel op een benchmark dac.....
en die zijn na wat mods subliem!
persoonlijk denk ik ook dat de matrix het beter zal doen, maar die HLLY ziet er gelikter uit.
In dubio
In dubio
- b_force
Het is dan toch "Ik kom terug van China en neem mee???"
(of "Ik ga naar China en neem terug???)
Iets meenemen naar China lijkt me niet zo handig
Tenzij je wilt dat ze het gaan kopiëren
Re: Ik ga naar China en neem terug???
Tjah tis dat het nogal een bedrag wordt anders zou ik zeggen gewoon beide;)
1680+1980=3660 = € 397.92
Ik zou een vriendinnetje meenemen, al is dat een stuk duurder
Ik zou geen vriendinnetje meenemen uit China hoor, allemaal compatibiliteitsproblemen. Ze lopen niet gewoon op aardappels met bloemkool enzo, andere programmeertaal dan europese vrouwen, lastig lastig allemaal
Ik heb toevallig van HLLY twee lm4780 versterkerboardjes gekocht via ebay, moet er nog versterkertjes van bouwen dus kan nog niks zeggen over de geluidskwaliteit maar heb om die reden voor het kopen gegoogled naar HLLY en er is op DIY wel wat over te vinden. Sommige producten worden wel goed getest iig.
Groeten Reinder
Groeten Reinder
Ahh bedankt voor de reacties, maar zoeken naar hifi in shanghai is een drama.
De locaties die ik op internet had gevonden waren reeds verouderd.
Ook geen internet kunnen vinden, dus nu maar gokken op mijn (schoon)familie in WhenZhou. Die kunnen me wel helpen. Ik heb het geluk dat HLLY in WhenZhou gevestigd is...
En anders wordt het een internetbestelling. Ik heb nog een paar weekjes te gaan..
Oh wat kosten betreft. Ik zit reeds met eentje opgescheept en twee kleine koters
Don't worry, DKM. Je bent niet de enige met een buitenlandse 'kostenpost'
Geezz!!!
In WenZhou hebben ze ook weinig gehoord van hifi.
Digital / Analog??? Wablieft?
En dat adres van HLLY is het hoofdkantoor zonder luistermogelijkheden.
Normaliter zou je denken dat er bij die chinezen erg makkelijk zijn als erg geld mee gemoeid is, maar de chef/directeur is er niet en die werknemers gaan niet harder lopen...
Trieste bedoeling zo.
Ziet er na uit dat ik een internetbestelling ga plaatsen...
- Boerenterprise
Ik hoop voor je dat de Nederlandse douane niet moeilijk gaat doen bij je terugkomt. Om een of andere reden moet ik vrijwel elke keer mijn koffer openen..... Afgelopen donderdag ben ik ook uit China terug gekomen, maar tot mijn verbazing stond er niemand die mijn koffer wilde zien
. Over een week ga ik weer en ben benieuwd of ik dan wel weer de koffer moet openen... Een tijdje terug ben ik samen met een collega geweest. Hij had bij terugkomst zijn eigen camera om zijn nek, maar daar deed men moeilijk over. We moesten ze overtuigen dat het toch echt een apparaat is welke in NL gekocht was, ver voor ons bezoek aan onder vlienden.
Chris
Chris
hemaworst schreef:Eentje van deze?![]()
Sorry had alleen titel gelezen
Daar kan ik wel een importbedrijf mee beginnen
Daar heb ik geen animocheck voor nodig.
Import kan natuurlijk altijd een probleem zijn. Eens kijken of ik geluk heb...
Internet in een bakkerij/eettentje... Altijd makkelijk
Is een matrix geworden. HLLY is nogal een apart bedrijfje, of ik klop aan de verkeerde deur..
Korte getest met een hoofdtelefoon gedaan, en hoop er het beste van.
Datzelfde geld voor de douane. Fingers crossed
Laatst gewijzigd door DKM op ma 01 aug 2011, 4:17, 1 keer totaal gewijzigd.
- Boerenterprise
Succes bij de douane....... Ik ben afgelopen maand 2x naar China geweest en beide keren stond er niemand bij de douane in Schiphol
Hallo allemaal ik ben nieuw op dit forum en wil meteen even inhaken op dit draadje.
Ik weet niet of je al naar China bent geweest maar momenteel ben ik helemaal gek van het ontwerp van de Audio-gd NFB-7 en -8!!
Ik weet niet of er gebruikerservaringen zijn van mensen hier?...
Dat is wel een beetje de reden waarom ik me hier ook heb aangemeldt. Ik hoop namelijk mensen te vinden die zo'n NFB-7 of -8 in huis hebben om ervaringen mee te delen.
Maar als het aan mij lag had ik zeker 1 van die 2 of allebei meegenomen
Ze zijn alleen wel bijna 15 kg haha!
Ik open wel een nieuw draadje voor mijn verdere vragen.
Ik onderzoek nl ook nog de mogelijkheid zelf een ultieme DAC te gaan bouwen.
Fijne vakantie iig als je nog niet geweest bent!
Grtz,
Jordo
Grtz,
Jordo
Net terug en geen controle gehad
(had ik maar meer meegenomen
Ik zal eerdaags een foto schieten, maar eerst luisteren!
- Boerenterprise
2 meenemen was een beetje teveel van het goede. Maar ik zou mijn familie kunnen vragen of ze er eentje op willen sturen..dre schreef:neem voor mij ook maar zo`n matrix mee!
Hier de beloofde foto's, intussen heb ik een geluidskaartje erbij gekocht voor de optische uitgang.
Het bevalt zeker goed, maar of deze ook jullie oortjes bekoren....
hanselchen
Deze week heb ik ook mijn Matrix Mini-I mogen ontvangen.
Mijn Chinese collega-techneut heeft er eentje voor me meegebracht tijdens zijn jaarlijkse bezoekje aan ons bedrijf.
Klinkt heel leuk met de Marantz en de Denon speler.
Zit er bij jouw DAC een afstandsbedienig bij inbegrepen?
De Chinese manual toont een afstandsbediening, de Engelse manual niet.
De doos heeft geen uitsparing waarin de remote zou moeten zitten.
Niet dat een afstandsbediening zo noodzakelijk is, maar het maakt me toch een beetje nieuwsgierig.
Mvg. Hans
Mvg. Hans
Die moet je inderdaad apart erbij kopen.
Kennissen hebben het erbij afgedwongen
btw ik heb het geluk gehad dat iemand de Hlly kwijt wilde. Nu heb ik ze beide
hanselchen
Dat je de afstandsbediening er apart bij moet kopen, dat staat nergens vermeld.
Maakt niet uit, ik zie er de meerwaarde toch niet zo van in.
En welke DAC heeft je voorkeur?
