Speaker Guru interview serie.
Roland
Bericht door Roland »
Hoi,
Ik ben van plan de speaker guru interview serie voortzetten. Deze:
http://members.aol.com/_ht_a/pjay99/
Hier staan onder andere interviews met; Vance Dickason, Linkwitz en anderen.
Ik wil de vragen voorleggen aan o.a: Tony Gee, Bernd Timmermans, Joachim Gerhard, Allan Isaksen, Troels Gravesen. En ze publiceren op Caps&Coils.
Als iemand nog een sterke vraag heeft? Of een idee wie ik de lijst npg meer kan voorleggen? Graag commentaar. Ik wil de vragenlijst wel enigzins overzichtelijk houden. Maar 2 of drie vragen kunnen er makkelijk bij.
Dit is de oude vragenlijst. Ik heb er een paar nieuwe bijgezet.
Speaker Designer Questions
Short bio
-What was the first speaker you build? And how did you get involved in speakerdesign or the audiofield?
-Can you tell us some more about your favorite music? Do you have special pieces of music you use to review loudspeakers?
-Without giving the standard “weakest link” answer, how important would you rate speakers as component?
-How have speakers changed in the past ten years?
-How about mechanical resistance in loudspeaker drivers. QMS and Rms. Important or overrated?
-Do we have to spend a lot on woofers and tweeters to get good sound?
-Do we have to spend a lot on capacitors and coils in the crossover to get good sound?
-About loudspeaker cabinets. Any thought on the use of exotic materials other than mdf?
-What are the top three design parameters you use? (or the top three things you worry about most)
-Do you design on measurement or sound?
-What do you think about dynamics? Must a speaker really be able to do 115 dB to be any good. Or is this overrated?
-What do you think is that "special something" is that makes some speakers sound so good?
-How many octaves does a speaker really need to sound right? Is the bottom octave required? What about above 20K?
-You have to choose: minimalist twoway monitor or a 4 way active loudspeaker. Which do you bring to the deserted Island?
-What one piece of advice you would like to give to every new speaker builder?
-Will we ever find the Holy Grail in sound reproduction? And what keeps us away from reaching this goal?
-So which is it for you, tubes or Solid State?
-Any thoughts on the audio industry's movement to the far east? -What does the future hold for speaker design?
-Will high end stereo be alive in twenty years?
-Can you name some loudspeaker designs you like? Commercial or DIY.
-And the final question, can you tell me were you are working on at the moment?
Vriendelijke groet
Roland
solitaire
Bericht door solitaire »
Philip Swift
Dick Olsher
Thorsten Loesch
John Bau
Edgar Villchur (ahum...leeft 'ie nog ...?)
Karl-Heinz Fink
John Dunlavy
Arnie Nudell
Stefan Stamm
qua vragen is de lijst al vrij compleet
leuk initiatief !
Wolf
Roland
Hoi,
Dank je, prima lijst. Ik probeer Thorsten Loesch al een poosje te pakken te krijgen. Kan alleen nergens zijn contact gegevens vinden. Dat zal bij die andere namen ook niet altijd makkelijk zijn. Maar ik ga het zeker proberen.
Alleen Dunlavy is niet meer. Jammer, die had lekker uitgesproken ideen over impulsgedrag, 1e orde filteren etc.
Iemand anders nog vragen of ideen voor geinterviewden?
weidok
Bericht door weidok »
Roland schreef:
Hoi,
Klaas Feenstra ???
weidok schreef:
Roland schreef:
Hoi,
Klaas Feenstra ???
Samen met zijn vriend Gerbrand van Veen? Dat wordt vast een spektakel.
Roland
De tips mogen ook wel wat exotischer als b.v. Klaas. Eens kijken of ik die man achter Feastrex te pakken kan krijgen. Dat lijkt me interresant.
Groet Roland
weidok
Groet Roland
Nou zeg...
heb je Klaas wel eens ontmoet en
zijn speksteenspeakers beluisterd...
Is echt een prachtig om naar zijn mooie verhalen
te luisteren.... met een groot gevoel voor humor :)
Exotischer kan bijna niet.... :) :)
Zeg Roland je had het over Thorsten..
was anders wel op diverse fora te vinden
maar de laatste maanden heb ik em
niet meer gezien !!
Ivo
Bericht door Ivo »
Hoi Roland, wist je dat Thorsten de laatste jarne zichzelf Kuey Yang Wang noemt op de fora? Hij werd nogal getarget met flames en hatemail, dus hij heeft zich teruggetrokken als Thorsten Loesch. Hij was toen ook wel een beetje irritant. Maar goed, hij weet ook veel, logisch dat hij zich overal mee bemoeide. Ik ken hem van het fullrange driver forum, van toen ik nog niets wist. Veel van geleerd.
Op diyaudio staat dit bedrijf in zijn signature: http://www.amr-audio.co.uk/index.htm. Ik weet dat hij ook bezig was om iets te beginnen met iemand anders, kennelijk is het gelukt.
hoewel ik wat tegen de term guru heb, lijkt het me wel een goed idee...
een naam die imho niet mag ontbreken is Gerd Lommersum,
en die gast van Crafty natuurlijk :lol:
Roland
weidok schreef:
Nou zeg...
Ik ken volgens mij alleen zijn alter ego Spido op Hear, daar zie ik de lol niet zo van in. Vandaar dat ik niet gelijk stond te juichen.
Gerd Lommersum is ook een heel goed idee. Die zal ik ook vragen. Die Audax man in Duitsland maakt ook mooie dingen. Proraum, weet even zijn naam niet. Dank je voor de Thorsten tips! Romy the Cat lijkt me ook een leuke.
Ik zal de vragen zelf ook beantwoorden :D. De naam Guru stond al vast door die eerdere reeks interviews. Ik heb net ook een mailtje binnen van PJay die de originele serie interviews begonnen is. Die is ook enthousiast en heeft er helemaal geen problemen mee als ik er verder ga met zijn idee :D.
Jeroen D even over het hoofd gezien. Zou je er aan mee willen werken Jeroen?
Groet
Roland
Ja hoor, prima. :)
Klaas zelf ook persoonlijk ontmoet. En inderdaad zijn alter ego links laten liggen en Klaas zelf aan het woord laten. Zal best nog wel eens lastig kunnen blijken, er is zo te merken veel "oud zeer".
Maar ik denk dat het voor jou best eens leuk zou kunnen zijn om hem eens op te zoeken in Appelscha.
weidok
Roland schreef:
Hoi,
Lukasz Fikus ? van Lampizator :)
een redelijk aantal van deze mensen (Gerd L in elk geval) zullen zeker weten op de beurs in Gelsenkirchen aanwezig zijn... dan kan je t ze persoonlijk vragen onder het genot van een bratwurst :D
nog een tip: Udo Wohlgemut
Roland
Het zal inderdaad best een vermakkelijke middag kunnen worden. Ik zie alleen Klaas Feenstra niet als een "Guru". Hij heeft vast veel mooie verhalen uit de oude doos, daar niet van. Maar nieuwe ideen of uitzonderlijk interresante speakers, zie ik niet op zijn PP site.
Daar komt bij dat ik iemand die "single handed" een forum om zeep helpt liever geen ruimte geef.
Klaas is in mijn ogen een "beperkte' guru. Hij heeft, voor zover mij bekend, veel voor de zelfbouw-wereld gedaan ten tijde van de Pied Piper. Maar misschien niet op het niveau wat jij zoekt.
Ik zal niet ontkennen dat daar ergens een steekje los zit. Het is echter aan de desbetreffende mods om zoiets te voorkomen.
Roland
Zo! De kop is er af! :D
Tony Gee heeft de vragenlijst beantwoord. http://www.capsandcoils.com/customer_reviews.html
Laatst gewijzigd door Roland op ma 15 sep 2008, 17:50, 1 keer totaal gewijzigd.
Martijn M
Bericht door Martijn M »
Moet ik me nou eerst registreren voordat ik kan zien wat Tony heeft geantwoord?
Nee, je kan gewoon meteen naar Reviews klikken.
Roland
Even de URL aangepast, daar hing nog mijn id aan leek het. Je kunt het interview gewoon lezen zonder in te loggen.
Groet Roland
solitaire
een feest om te lezen !
W.
Christian
Bericht door Christian »
Inderdaad! Leuk initiatief!
GeertM2
Bericht door GeertM2 »
Superleuk om te lezen.
Wellicht Bert Doppenberg?
Roland
Dank voor de complimenten!
Troels Gravesen is op het moment bezig de lijst met vragen te beantwoorden. En ik ben er zelf ook druk mee bezig. Het is erg leuk om te doen :D . P. Jay heeft ook nog een hele lijst met mensen die hij graag wil interviewen. We zijn voorlopig nog wel even zoet 8) .
Groet Roland
arjank
Bericht door arjank »
Die man van Proraum is Rainer Kronke, die man heeft zeer veel ervaring en een zeer goede meet en luisterruimte.
Misschien is het ook leuk om Robert Bastani die lijst te laten invullen!
Gesloten
