Grace Design M903
Geplaatst: za 04 okt 2025, 12:18
Te Koop,
Mijn Grace Design M903 DAC/pre amp/headphone amp with crossfeed
Is altijd bij mij thuis gebruikt in een actief speaker systeem als DAC en controller voor de luidspreker, maar staat nu na de aanschaf van een MiniDSP werkloos, en mag dus weg. Let op, moet niet weg.
Komt in originele verpakking, ik Ben de eerste eigenaar.
Zie onderstaande voor de specs en op het www is genoeg te vinden over dit apparaat.
Specs
SPECIFICATIONS ANALOG IN
Gain – Balanced Input
Headphone output, volume at maximum 0dB
Balanced Line output, volume at maximum +4dB
Unbalanced Line output, volume at maximum -8dB
Frequency Response – Unbalanced In > Unbalanced Out
@ 0dBu out +/- .25dB 27Hz – 54kHz
@ 0dBu out +/- .5dB 18Hz – 80kHz
@ 0dBu out +/-3dB 6.5Hz – 226kHz
Maximum Input Level
Balanced Input +22dBu
Unbalanced Input +16dBu
Maximum Output Level
Unbalanced output @1kHz, 100k Ohm load +21.5dBu
Balanced output @1kHz, 100k Ohm load +27dBu
Headphone output @1kHz, 50 Ohm load +20dBu
Impedance
Balanced Input 106K Ohms
Unbalanced Input 53K Ohms
Balanced Output 95 Ohms
Unbalanced Output 47.5 Ohms
Headphone Output 1.2 Ohm
Dynamic Range
@ 0dB gain, Balanced In > Balanced Out 117dB
@ 0dB gain, Balanced In > Headphone Out 116dB
THD+N Balanced Input
Headphone Out @ +10dBu, 50 Ohm load, SMPTE 4:1 <0.020%
Headphone Out @ +10dBu, 50 Ohm load <0.0060%
Unbalanced Line Out @ +10dBu, 100k Ohm load <0.00026%
Balanced Line Out @ +20dBu, 100k Ohm load <0.00036%
Attenuator
Channel matching <0.05dB
Attenuator Range 97.5dB
Output Noise Floor, Balanced Input
Balanced Output, volume at maximum, 22-22kHz -90dBu
Balanced Output, volume at minimum, 22-22kHz -103dBu
Unbalanced Output, volume at maximum, 22-22kHz -101dBu
Unbalanced Output, volume at maximum, 22-22kHz -105dBu
SPECIFICATIONS D/A CONVERTER
Input Sample Rate 32, 44.1, 48, 88.2, 96, 176.4, 192kHz
THD+N
44.1kHz, 24bit, 1kHz, -1dBFS, Unbalanced Out @ +15dBu <0.0009%
44.1kHz, 24bit, 1kHz, -1dBFS, Balanced Out @ +15dBu <0.0006%
Output level
Unbalanced Output @ 0dBFS, Volume at maximum, trim at 0 +9dBu
Blanced Output @ 0dBFS, Volume at maximum, trim at 0 +21dBu
Power Requirements
120VAC 0.16A
230VAC 0.08A
DIMENSIONS AND WEIGHT
Dimensions H1.7” x W8.5” x D8.25”
Weight 5 lbs (2.2kg)
De vraagprijs is 900 euro.
Met vriendelijke groet,
Kermy
Specs
Maximum Input Level
Impedance
Dynamic Range
Attenuator
THD+N
Output level
Power Requirements
120VAC 0.16A
230VAC 0.08A
Kermy
