LME49810 versterker PCB: zijn de chips origineel?
Wasverzachter
Berichtdoor Wasverzachter » vr 18 sep 2020, 20:32
Met al die verhalen op internet over nagemaakte chips, vraag ik me af hoe groot de kans is dat hier originele chips op zitten.
Zeker gezien de EOL status van de betreffende LME.
Het gaat om deze versterker:
This high precision mono bipolar amplifier delivers 300 W under 8 ohm. Equipped with precision metal resistors, quality capacitors, this kit is ideal for high power amplification modules with high-fidelity sound quality.
It is designed around 6 bipolar transistors 2SC5200 NPN and 2SA1943 PNP of high quality Toshiba .
Their modularity and ease of implementation make them a reference choice for any dual mono stereo DIY amplifier project or for multichannel amplifiers.
These transistors are controlled by the integrated driver " LME49810" with a "Soft Clipping" overload protection system.
Single module sold per unit.
Main Features:
Power Transistors: BIPOLAR NPN TTC5200x3, PNP TTA1943x3.
Transistor stage transistor: LME49810.
8 capacitors 680μF 63V.
Mono input stage OP AMP TL071 JFET.
Output power: 300W on 8 Ohm.
Recommended average operating voltage 55 VDC.
Frequency response: 20Hz - 25kHz + -0.5dB.
Noise background 93dBu.
Slew-rate: 50V / us.
Distortion rate: 0.0007% at 1 K HZ 50W on a resistance of 8Ohm.
Signal-to-Noise Ratio (SNR):> 114dB.
Requires to operate a power supply of at least + /-55V VCC (See accessory).
Inputs and outputs:
Power supply and speaker output via screw terminal block.
Mono input via screw terminal block.
Dimensions and weight:
PCB dimensions: 207x93x35mm.
Mounting brackets: 206X85mm.
Weight: 305gr the mono module.
Sold individually.
Supplied with insulation film for power transistors.
Supplied with spacers.
Provide a linear supply of +/- 55V and a transformer from 30V AC to 38V AC.
Gezien op deze website: https://www.audiophonics.fr/en/amplifie ... 11189.html
Wat opvalt is dat de specs overgenomen lijken te zijn uit de datasheet.
Een kleine zoektocht op alie laat nog meer van dit soort bordjes zien, sommigen ook met meer eindtransistorparen.
Wat betreft de eindtorren ben ik niet zo heel bang voor namaak (die zijn nog goed te vinden).
De LME is een ander verhaal. Ik dacht ergens gelezen te hebben dat ze voor een order van minimaal 120 stuks wel kunnen leveren. Dat is zo ver ik weet niet gebruikelijk voor een EOL chip. Lijkt me stug dat ze dan speciaal 1 wafer belichten.
Heeft iemand wellicht ervaring met dit soort verhalen?
Re: LME49810 versterker PCB: zijn de chips origineel?
Berichtdoor Shadow » vr 18 sep 2020, 22:20
Je bent bekend met het fenomeen ‘loterij’? Dit kan heel goed werken, maar garantie nee....
Wasverzachter
Berichtdoor Wasverzachter » vr 18 sep 2020, 22:36
Vorig jaar eindcijfer 19 (bewust 18+ gespeeld), geen resultaat :rofl:
Ik wacht wel af en anders word het inderdaad dobbelen.
Berichtdoor ray5150 » za 19 sep 2020, 1:21
Heb er zelf geen ervaring mee, maar de naam van Audiophonics komt hier geregeld voorbij, en is voor zover ik weet een leverancier die wel betrouwbaar is.
Het verbaasd mij eerder dat er anno 2020 nog mensen zijn die een versterker willen bouwen en niet met een Class-D printje, buizen of Hypex aan de slag gaan. :shock:
Overigens wil het feit dat een bepaalde chip recentelijk niet meer gemaakt word wil niet zeggen dat alles gelijk imitatie is wat verkocht word. er zijn er immers vaak nog duizenden exemplaren die bij diverse tussenhandelaren liggen. zou wel uitkijken met Aziatische leveranciers.
Berichtdoor Barry2001 » za 19 sep 2020, 9:10
De elco's zijn in elk geval al merkloos. Zoals hiervoor al gezegd, je hebt geen idee wat je hier koopt, kan van alles zijn. Audiophonics is geen distributeur, maar vooral een doorschuiver van chinese produkten. Misschien zijn de LME's wel origineel en lag er nog ergens een batch, de kans dat de machines zijn aangezet om voor dit product er nog wat te stampen, is 0.
Maar misschien werkt het wel volgens specs, misschien een week, misschien een jaar, kortom weet je gewoon niet.
Berichtdoor Pjotr » za 19 sep 2020, 11:58
Vooropgesteld: Mijn ervaring met Audiophonics is dat ze beslist geen troep verkopen en een goede service leveren.
Die LME49810 is geen ding wat interessant genoeg is voor de Chinezen om te gaan kopiëren. Dat doen ze alleen met dingen wat als bulk verkocht kan worden. Zomaar een tjippie bakken met het kunstje van de LME49810 is ook voor de Chinezen nog niet zo eenvoudig. Anders ligt dat met de Toshiba transistoren. Die zijn erg gewild en dan draaien ze hun hand er niet voor om om een zelfgebakken powertor die in de richting komt over te schilderen in de Toshibakleuren.
Wasverzachter
Berichtdoor Wasverzachter » za 19 sep 2020, 13:43
@Ray: Ze zeggen dat er meerdere wegen zijn die naar Rome - Leiden :bakkie: Buizen zijn heel mooi maar ik heb er simpelweg niet genoeg verstand van om aan zoiets te beginnen.
@Barry: ik dacht al; barst, die herken ik niet. Wat ook opvalt op de foto's van audiophonics is dat er ergens in het midden een foto te zien is van wat aansluitingen. Daarop is een Omron relais te zien, op de rest van de foto's weer niet... :think:
@Pjotr: Die torren maak ik me gelukkig wat minder druk om. Heb voor een paar tientjes een defecte versterker gekocht waar ze al in zitten. Een van de printen heeft kortsluiting. Zou het kunnen repareren maar dan blijft het een of ander klasse H print, soort kopie van een QSC.
De service waar je het over hebt lijkt me dan wel belangrijk. Mocht de print niet aan de specs voldoen kan ik het gewoon terugsturen.
Bedankt voor jullie input. :goedzo:
Berichtdoor ray5150 » za 19 sep 2020, 13:48
Ga je hem dan nameten met een Audio Precision of iets dergelijks ?
Wasverzachter
Berichtdoor Wasverzachter » za 19 sep 2020, 14:16
Ik weet niet wat dat is Ray?
Volgende cijfers zijn loopbackmetingen van een Asus Essence STX II (7.1, maar van de 'hoofd' stereo uitgang) gemeten met Arta.
Het eerste getal is het percentage van windows volume regeling op de taakbalk.
Perc/THD
100/0.0007
80/0.0007
60/0.00064
40/0.00049
30/0.0007
25/0.001
20/0.0015
15/0.0026
10/0.0049
8/0.0078
6/0.01
4/0.03
2/0.08
1/0.24
Overigens is de THD+N bij volume op 100% gelijk aan 0.002% veroorzaakt door een 50Hz brommetje vlak boven de ruisvloer.
Lijkt me dat deze DAC/ADC combo precies genoeg is voor een meting?
Berichtdoor ray5150 » za 19 sep 2020, 19:30
Wasverzachter schreef:Ik weet niet wat dat is Ray?
Audio Precision is een Amerikaanse fabrikant van hoogwaardige (en kostbare) meetapparatuur speciaal gemaakt voor audio toepassingen.
https://www.ap.com/
Wasverzachter
Berichtdoor Wasverzachter » za 19 sep 2020, 21:02
AP zal wel klinken als een klok.
Maar zowel voor de klokkies als de meetapparatuur heb ik het budget niet.
Ik ben maar een eenvoudige jongen.
Denk je dat ik zoiets nodig heb om een versterker te kunnen meten? Ik dacht: line-out>amp>line-in.
Berichtdoor Shadow » zo 20 sep 2020, 8:58
Je zegt het zelf al: 'line', na een vermogensversterker zit je niet meer op 'line' niveau :-k
Wasverzachter
Berichtdoor Wasverzachter » zo 20 sep 2020, 14:51
Lijkt me inderdaad niet handig, dan blaas ik de ingang op.
Ik lees dat je een spanningsdeler kunt maken met twee weerstanden, 20k en 2k om een 1:10 deling te krijgen.
Nou lijkt me dat het ook wel belangrijk is om de versterker te belasten met een realistische load. Ik heb wel wat vermogensweerstanden van 20w, 8,2Ohm. Kan ik er daarvan eentje parallel aan de spanningsdeler zetten?
Berichtdoor ray5150 » zo 20 sep 2020, 14:55
Zou er meerdere nemen in een serie-parallel schakeling.
Terug naar “Versterkers”
Gebruikers op dit forum: CCBot, douwebakker, erik1977 en 1 gast
