2x Eminence ALPHA-15A
Toni
Berichtdoor Toni » ma 16 dec 2019, 14:40
ZGAN, maar gebruikt, wel aan gesoldeerd, en de korf verstevigd met bitumen.
Onbeschadigd, geen org verpakking.
Dankzij hoge QTS goed bruikbaar in open baffle.
Nieuwprijs per stuk is 139 euro
Nu 2 stuks voor 100 euro.
Verzendkosten 6,95
pecification
Nominal Basket Diameter 15", 381 mm
Nominal Impedance* 8 Ω
Power Rating*
Program Power 400 W
Watts 200 W
Resonance 41 Hz
Usable Frequency Range 46 Hz - 3.5 kHz
Sensitivity* 97 dB
Magnet Weight 25 oz.
Gap Height 0.25", 6.4 mm
Voice Coil Diameter 1.5", 38 mm
Thiele & Small Parameters
Resonant Frequency (fs) 41 Hz
DC Resistance (Re) 5.88 Ω
Coil Inductance (Le) 0.84m H
Mechanical Q (Qms) 7.23
Electromagnetic Q (Qes) 1.53
Total Q (Qts) 1.26
Compliance Equivalent Volume (Vas) 260 liters / 9.18 cu.ft.
Peak Diaphragm Displacement Volume (Vd) 325 cc
Mechanical Compliance of Suspension (Cms) 0.25 mm/N
BL Product (BL) 7.7 T-M
Diaphragm Mass Inc. Airload (MMs) 59 grams
Efficiency Bandwidth Product (EBP) 27
Maximum Linear Excursion (Xmax) 3.8 mm
Surface Area of Cone (Sd) 856.3 cm2
Maximum Mechanical Limit (Xlim) 8.4 mm
Mounting Information
Recommended Enclosure Volume
Sealed 71-85 liters / 2.5-3 cu.ft.
Vented 106-177 liters / 3.75-6.25 cu.ft.
Driver Volume Displaced 0.113 cu.ft. / 3.21 liters
Overall Diameter 15.15", 384.8 mm
Baffle Hole Diameter 13.87", 352.3 mm
Front Sealing Gasket Yes
Rear Sealing Gasket Yes
Mounting Holes Diameter 0.25", 6.4mm
Mounting Holes B.C.D. 14.56", 369.8mm
Depth 5.83", 148.1 mm
Net Weight 6.7 lbs, 3.04 kg
Shipping Weight 8.8 lbs, 3.99 kgs
Materials of Construction
Coil Construction Copper voice coil
Coil Former Polyimide former
Magnet Composition Ferrite magnet
Core Details Vented and extended core
Basket Materials Pressed steel basket
Cone Composition Paper cone
Cone Edge Composition Cloth cone edge
Dust Cap Composition Solid composition paper dust cap
Xeres
Re: 2x Eminence ALPHA-15A
Berichtdoor Xeres » vr 12 jun 2020, 11:18
Ha Toni,
Heb jij deze drivers nog?
Ik hoor het graag, groet Raymond
Toni
Berichtdoor Toni » vr 12 jun 2020, 11:26
Hoi Raymond,
Sorry, al lang geleden verkocht, zal de ad updaten.
Gr,
Toni
Terug naar “Archief”
