SEAS Odin MkIII, A dream comes true......
Hondasnl
Berichtdoor Hondasnl » wo 08 aug 2007, 20:19
Bouwverslag Odin MkIII (Mk3) van Seas
Met wat aanpassingen qua uiterlijk zullen deze, in dit verslag, gebouwd gaan worden.
Er wordt absoluut niet gerommeld aan het filter, gebruikte drivers, kastinhoud e.d.
Informatie originele kit:
http://www.seas.no/index.php?option=com ... &Itemid=42
Odin MK3
The Odin Mk3 is a completely redesigned version of the very popular Odin kit, utilizing the latest drive unit technologies from the Excel product line.
This kit uses two W18E001 woofers and a single T25CF002 "MILLENNIUM" tweeter mounted in a D'Appolito configuration.
The cabinet is a bass reflex design with the vent placed in the rear.
This directs any potential vent noises away from the listener, and allows for minimum baffle area in the front.
The pvc port tube is supported by an internal baffle which helps maintain equal air flow on each end of the tube, and also serves as additional cabinet bracing.
The port tuning frequency is 31Hz.
The crossover network is conventional except for a parallel circuit which supresses the response peak due to the magnesium cone.
The crossover frequency is 2.5kHz.
The Odin Mk3 was designed by Dr. Joseph D'Appolito, and was developed as a companion kit to the Thor transmission line system.
He offers the following comments regarding the performance of the Odin MK3:
"The vented box is tuned about 15% lower than the ubiquitous QB3 alignment to yield a better damped bass response.
Several hundred hours of laboratory testing and listening have gone into this system.
You literally can't tell where the woofers leave off and the tweeter begins.
Probeer met regelmaat de vorderingen van de bouw te tonen m.b.v. veel foto's.
Maar let wel, ik heb er geen haast mee, moet eerst een goed ontwerp maken.
Daarvoor heb ik ook jullie hulp nodig.
Dus opmerkingen en verbeteringen zijn zeer op prijs gesteld!
Veel plezier!!!
Met vriendelijke groeten,
Marcus den Boer
Hieronder ook de up-to-date tekeningen, die in het verloop van het project tot stand zijn gekomen.
Laatst gewijzigd door Hondasnl op do 28 jul 2011, 7:13, 164 keer totaal gewijzigd.
Een gevorderde autist.
Hondasnl
De eerste plannen.
Berichtdoor Hondasnl » wo 08 aug 2007, 20:25
Hier begint het verslag vanaf NUL ......
Hierbij de eerste plannen.
Kasten worden van 18mm massief Zuid Amerikaans eiken panelen + 9mm mdf + 4mm loodbitumen = ca. 31mm dikte.
Wanden worden bekleed met 41mm pritex.
Onderste compartiment wordt gevuld met zand.
De units:
Excel by SEAS
- 2x W18E001
- 1x T25CF002
Laatst gewijzigd door Hondasnl op vr 26 okt 2007, 12:54, 15 keer totaal gewijzigd.
mikekiwi
Berichtdoor mikekiwi » wo 08 aug 2007, 20:52
Zo..alleen de tekening al...daar is over nagedacht en mooi uitgewerkt. Met wel programmaatje gedaan als ik het vragen mag?
Hondasnl
Berichtdoor Hondasnl » wo 08 aug 2007, 20:56
mikekiwi schreef:Zo..alleen de tekening al...daar is over nagedacht en mooi uitgewerkt. Met wel programmaatje gedaan als ik het vragen mag?
Hoi MikeKiwi,
M'n werk is ook wel een beetje m'n hobby, CAD-tekenaar. :wink:
Erg handig programma. De inhoud is dan ook 34 liter gebleven.
Laatst gewijzigd door Hondasnl op do 09 aug 2007, 13:59, 1 keer totaal gewijzigd.
CarloPJB
Berichtdoor CarloPJB » wo 08 aug 2007, 20:58
Wat `n begin..............Dit ga ik zeker volgen.
Misschien kun je verticaal nog `n bracing doen op de helft van de zijkant.
En je zou aan de binnenzijde v/d kast 2 plaatjes Mdf kunnen gebruiken voor de BR-poort.Een om hem in te centreren en de tweede om `n mooie radius aan te frezen.
Hondasnl
Berichtdoor Hondasnl » wo 08 aug 2007, 21:10
CarloPJB schreef:Wat `n begin..............Dit ga ik zeker volgen.
Hoi CarloPJB,
Die vertikale bracing, die komt erin.
Zou jij dat doen met losse balkjes, of half inelkaar in laten grijpen met de horizontale bracing's :?:
Morgen de tekening aanpassen.
Bedankt voor je tip :!:
Laatst gewijzigd door Hondasnl op do 09 aug 2007, 13:58, 1 keer totaal gewijzigd.
Hondasnl
Berichtdoor Hondasnl » wo 08 aug 2007, 21:13
Dus 1 halverwege en 1 aan het begin? dus in de kast, voorzien van een mooie radius?
En waar die de kast verlaat recht houden?, of ook met een mooie radius?
Laatst gewijzigd door Hondasnl op do 09 aug 2007, 13:58, 2 keer totaal gewijzigd.
CarloPJB
Berichtdoor CarloPJB » wo 08 aug 2007, 21:14
Hoi CarloPJB,
Ik heb tot nu toe altijd met losse delen gewerkt maar met het project waar ik nu aan bezig ben (St_Amati) wil ik de delen ook in elkaar laten grijpen.
Denk wel dat dit bewerkelijker is en weet niet of en hoeveel beschikking je hebt over `n goede zaagtafel.
Groet,Carlo
Hondasnl
Berichtdoor Hondasnl » wo 08 aug 2007, 21:16
CarloPJB schreef:
Hondasnl schreef:
CarloPJB schreef:Denk wel dat dit bewerkelijker is en weet niet of en hoeveel beschikking je hebt over `n goede zaagtafel.
Groet,Carlo
Nee, ik heb niet zo'n grote zaagtafel, maar dat komt wel goed.
CarloPJB
Berichtdoor CarloPJB » wo 08 aug 2007, 21:19
2 aan het begin en 2 aan het eind.
Op deze manier.Hoop dat het `n beetje duidelijk is.
De eerste laag is waar de poort precies pas in zit en aan de tweede binnen en buiten mooi rond frezen.
Hondasnl
Berichtdoor Hondasnl » wo 08 aug 2007, 21:24
Ja, nu is het me duidelijk!
Aardig stukkie werk ook!!!
Bedankt
nlmb
Berichtdoor nlmb » wo 08 aug 2007, 22:45
Het filter kan je natuurlijk ook helemaal in het zand begraven.
Niet lullen maar bouwen :).
Hondasnl
Berichtdoor Hondasnl » wo 08 aug 2007, 23:51
nlmb schreef:Het filter kan je natuurlijk ook helemaal in het zand begraven.
Dan kun je er later toch niet echt makkelijk meer bij!?
Aanpassingen zullen zeker wel uitvoerbaar moeten zijn.
Hondasnl
Berichtdoor Hondasnl » do 09 aug 2007, 11:31
Ontwerp aangepast met extra vertikale bracings en vloeiende basspijp uiteinden.
Bedankt voor je tip Carlo! :wink:
Laatst gewijzigd door Hondasnl op vr 26 okt 2007, 15:39, 3 keer totaal gewijzigd.
Edo
Mede-oprichter
Berichtdoor Edo » do 09 aug 2007, 12:10
He Marcus,
Leuk ontwerp. En handig zo de tekeningen maken. (moet ik ook eens aan beginnen).
Even klein dingetje: Hou je nog rekening met een dikke baffle (front) en dat de woofer wat lucht heeft (de kast in)? Hieronder een voorbeeld wat ik bedoel.
of
Ga je daar nog wat afronden?
Edo
Hondasnl
Berichtdoor Hondasnl » do 09 aug 2007, 13:11
Hoi Edo,
Goed dat je het zegt, weer een goede en zeer bruikbare tip!!
Dikte baffle is nu 18+9mm = 27mm.
Ik denk dat ik er een ronding infrees, net als bij de basspijp.
Dat moet wel volstaan denk ik, zeker als ik kijk naar het originele ontwerp van Seas, die doen daar helemaal niets aan en dat bij een baffel van 22mm.
Enkel zal ik dan de bacings daar terplekke wat verder van het woofergat moeten positioneren.
Tekening wordt dus wederom aangepast!
Als dit zo door gaat, wordt het dalijk wellicht nog wat :D .
Hier een kerel die de standaard versie aan het bouwen is:
http://www.dame-electric.com/projects-odin.htm
jantje-secuur
Berichtdoor jantje-secuur » do 09 aug 2007, 13:18
Ziet er erg goed uit op de tekening Hondasnl!
Mag ik vragen waar jij 'egyptisch speakerdoek' vandaan kunt halen? Het ziet er opzich wel leuk uit namelijk.
In elkaar grijpende bracings zijn met goed aftekenen en een decoupeerzaag prima te doen hoor. Eventueel wat bruislijm om - eh - wat fouten te corrigeren. ;)
Hondasnl
Berichtdoor Hondasnl » do 09 aug 2007, 13:21
Hoi Interficior,
Ik moet je eerlijk zeggen dat ik zo maar een z.g. "hatch patroon" van AutoCad heb gebruikt.
Ben eigenlijk opzoek naar bruin luidsprekerdoek, nergens kan ik dat vinden :( .
Maaruh, hier een leuke site van dat stufff:
http://www.corrienmaas.nl/hoofdframe/radiodoek.htm
Laatst gewijzigd door Hondasnl op do 09 aug 2007, 13:57, 1 keer totaal gewijzigd.
Hondasnl
Berichtdoor Hondasnl » do 09 aug 2007, 13:52
Bedankt Edo :wink: , ik heb je commentaren verwerkt, meer lucht voor de woofers door er een ronding in te frezen.
Laatst gewijzigd door Hondasnl op vr 26 okt 2007, 15:40, 3 keer totaal gewijzigd.
Berichtdoor dre » do 09 aug 2007, 20:47
he marcus,ik zie dat je een mooi topic er over hebt geopend 8)
we hadden deze week contact gehad over de kast en filter onderdelen.
gr. dre
Berichtdoor Henkjan » do 09 aug 2007, 20:54
Hondasnl schreef:Ben eigenlijk opzoek naar bruin luidsprekerdoek, nergens kan ik dat vinden :( .
Speaker&Co al geprobeerd? daar heb ik een paar weken terug nog wat gehaald
Hondasnl
Berichtdoor Hondasnl » do 09 aug 2007, 21:04
dre schreef:he marcus,ik zie dat je een mooi topic er over hebt geopend 8)
gr. dre
Heeeejj Andre!
Wat is het wereldje toch klein! :lol:
Filtering, dat komt zeker aan de orde.
Dan zal ik zeker nog een beroep op je doen! :wink:
Dit moet hem worden, wellicht met nog betere componenten!? en natuurlijk Bi-wired:
1e schema: Standaard schema:
2e schema: Bi-wired:
Laatst gewijzigd door Hondasnl op vr 26 okt 2007, 15:42, 5 keer totaal gewijzigd.
Hondasnl
Berichtdoor Hondasnl » do 09 aug 2007, 21:06
Hoi Henkjan, ja die hebben helaas enkel zwart, blauw en grijs meen ik.
Hondasnl
Berichtdoor Hondasnl » ma 13 aug 2007, 12:15
Na de TL's dit weekeind succesvol verkocht te hebben en er zeker het materiaal uit had, moest ik toch even wat ter overbrugging aanschaffen. Correct adverteerde met de Wharfedale's Diamond 9.5 voor 129 euro per stuk en 5 jaar garantie.
Ik heb even op internet gezocht, maar zo goedkoop ben ik ze nog niet tegengekomen, elders worden deze kistjes verkocht tussen de 356 en 498 euro per paar.
Link naar Correct, technische omschrijving klopt niet helemaal, het is een 3-weg systeem:
http://www2.correct.com/artikel.php?VOORRAADSOORT=A&KLASSE=2&SOORT=9942&ARTNR=299793&PHPSESSID=5017826e112d8930bf6153e519c641f2
Wat gegevens:
Prijsvergelijk Wharfedale Diamond 9.5
12 winkelprijzen van € 178 tot € 498
Formaat vloerstaand
Type speaker 3-weg
Aantal speakerunits 3
Tweeter-units per speaker 1
Tweeter diameter 25 mm
Midrange-units per speaker 1
Midrange diameter 165 mm
Woofer-units per speaker 1
Woofer diameter 165 mm
Basreflexpoort
Aanbevolen min. vermogen 30 watt
Aanbevolen max. vermogen 150 watt
Gevoeligheid 88 dB
Impedantie 6 Ohm
Frequentie bereik 30-24000 Hz
Cross-Over frequentie(s) 0,14, 2,2 kHz
Geschikt voor bi-wiring
Magnetisch afgeschermd
Kleur(en) rosewood; beech; cherry; black; silver
Introductie model 2004
Afmetingen (H x B x D) 90 x 22,3 x 30,1 cm
Website http://www.transtec.nl
Nadat ik ze had aangesloten.... BAH BAH wat klonk dat donker en muf.
Het leek wel of het geluid door een zak vol met wol ging.
Eerst maar eens die baspijpen wat dichten met wat wol.
Nog niet alles, maarja spelen dan maar.
Na een tijdje in te spelen, begonnen ze wat sprankelijkere geluiden te produceren.
Ik heb de mid er eens uitgeschroefd om eens te kijken hoe dat er van binnen nu uit zag.
In iedergeval mooie aluminium gegoten units, enkel de demping en de bekabeling kwamen wat dunnetjes over.
Ook het filter was wel wat minder.
Nu 2 dagen in huis, ik moet je eerlijk zeggen dat dit erg veel waar is voor je geld. Ze gaan steeds beter klinken.
De frontjes is een drama, die zijn van erg slap plastic, pootjes breken dan ook snel af.
Voor de niet-doehetzelver een aanrader dus!!!!!
Laatst gewijzigd door Hondasnl op vr 26 okt 2007, 15:45, 2 keer totaal gewijzigd.
Hondasnl
Berichtdoor Hondasnl » ma 13 aug 2007, 21:10
Materiaalkeuze kast.
Ik ben eens even wezen shoppen bij de Formido hier, ze verkopen ook 26mm dikke werkbladen in 4 verschillende houtsoorten.
T.w.: Zuid Amerikaans eiken, Beuken, Hardhout en Eucalypt.
Mijn voorkeur gaat weer uit naar Zuid Amerikaans eiken, waar ik zeer goede ervaringen mee heb.
Prijzen bladafmeting 250 * 60 * 2.6:
Zuid Amerikaans eiken 159,-
Beuken 119,-
Hardhout 139,-
Eucalypt 95,-
Prijzen bladafmeting 200 * 80 * 2.6:
Zuid Amerikaans eiken 179,-
Beuken 149,-
Hardhout 149,-
Eucalypt 105,-
Niet echt goedkoop, maar je zit niet te klooien met die extra 9mm laag mdf.
Ik zal eens een plaatindeling maken van hetgeen wat echt nodig is voor de kast. Interne delen en onderzijde maak ik gewoon van mdf.
Als je hem dan ook nog goed bekleed met loodbitumen, zal het wel een stevige en degelijke dode kast worden, aldus mijn ervaringen met de TL en de Standaard van Speaker & Co.
Laatst gewijzigd door Hondasnl op vr 26 okt 2007, 15:44, 1 keer totaal gewijzigd.
Terug naar “Oude Showcases”
